  • 10
markw96
Message 1 of 11
Superhub losing connection
For the past month or so I have been constantly losing Internet connection whilst connected via WiFi to my virgin media superhub (original version)
The WiFi stays connected but the Internet connection is lost/not accessible.
Is there a way I can run tests on the modem to see what the issue is?
  • 21.83K
  • 626
  • 3.66K
Sephiroth
Message 2 of 11
Re: Superhub losing connection
You can post the modem stats (downstream & upstream) by going to url 192.168.01 and selecting ROUTER STATUS.  Then copy/paste them into your thread.
  • 10
markw96
Message 3 of 11
There is no router status. The only options I have are:wireless network settings, superhub settings and device connection status.
(advance settings option at the bottom of the page)
  • 21.83K
  • 626
  • 3.66K
Sephiroth
Message 4 of 11
Do it without logging in. If it's a hub 3, in the middle of the login screen it'll say "Check router status". Use that link.
  • 10
markw96
Message 5 of 11
It's the original super hub. 1
  • 21.83K
  • 626
  • 3.66K
Sephiroth
Message 6 of 11
Then the ROUTER STATUS link is in the top right hand corner.
Anyway, the original SH 1 is a wireless fail and the VM bods, when they eventually get to this thread, will likely offer you a Hub 3.
  • 10
markw96
Message 7 of 11
Downstream
Downstream  DS-1 DS-2 DS-3 DS-4 DS-5 DS-6 DS-7 DS-8139000000 Hz 147000000 Hz 155000000 Hz 163000000 Hz 171000000 Hz 179000000 Hz 187000000 Hz 195000000 HzLocked Locked Locked Locked Locked Locked Locked Locked1 2 3 4 5 6 7 8QAM256 QAM256 QAM256 QAM256 QAM256 QAM256 QAM256 QAM2566.952000 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000I=12J=17 I=12J=17 I=12J=17 I=12J=17 I=12J=17 I=12J=17 I=12J=17 I=12J=17-0.1 dBmV -0.4 dBmV -0.9 dBmV -1.3 dBmV 0.7 dBmV 0.6 dBmV 0.3 dBmV -0.1 dBmV37.8 dB 37.8 dB 37.8 dB 37.8 dB 38.0 dB 38.1 dB 38.2 dB 38.2 dB
Frequency (Hz)
Lock Status(QAM Lock/FEC Sync/MPEG Lock)
Channel ID
Modulation
Symbol Rate (Msym/sec)
Interleave Depth
Power Level (dBmV)
RxMER (dB)
  • 10
markw96
Message 8 of 11
Upstream
US-1 US-2 US-3 US-42.0 2.0 2.0 2.09 10 11 1246200000 Hz 39400000 Hz 32600000 Hz 25800000 HzSuccess Success Success SuccessQAM64 QAM64 QAM64 QAM645120000 5120000 5120000 512000064 64 64 6440.0 dBmV 40.3 dBmV 40.0 dBmV 39.8 dBmV0 0 0 00 0 0 00 0 0 00 0 0 0
Channel Type
Channel ID
Frequency (Hz)
Ranging Status
Modulation
Symbol Rate (Sym/sec)
Mini-Slot Size
Power Level (dBmV)
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
  • 9.5K
  • 993
  • 1.5K
Message 9 of 11
Should be in a museum.  Call it in as a fault and just say your Superhub1 has stopped broadcasting wifi and you cant connect any of your phones or tablets.  Every time they make you restart it just say "nope, still cannot connect my phone" and insist on getting it fixed.  The will either send you a Hub3 in the post or a technician to take a look - who wont waste any time and simply swap it out for the Hub3.
  • 21.83K
  • 626
  • 3.66K
Sephiroth
Message 10 of 11
Nothing wrong with the circuit in those stats.
Keep us posted.
