on 10-02-2022 17:17
I've had the Superhub 5 for about a month but I can honestly say I'm not impressed at all . I have a constant issue with the hub disconnecting at the same time most nights with flashing white lights - It does come back up after 10-15 mins but it's incredible annoying as i rely on having a constant connection for work purposes
I've tried phoning Virgin Media's help line but when I finally got through to a human, whoever that person was - put the phone down on me (I expect it was 5pm and they decided it was more important to go home)
Virgin , Your customer service is absolutely atrocious
Has anyone got an idea on what the hell is going on and how to fix it. I assumed at first it was superhub updates since the hub is fairly new but it's frankly gone on too long
on 10-02-2022 17:30
Flashing white LED (fading in and out) supposedly means the hub is booting up.
The LED is supposed to flash green when it is downloading a software update.
Have you tried factory reseting your Hub 5? This resolved most of my issues with it.
I have only had mine just over a week, but BQMs show no packet loss for the last two and a bit days.
I too rely on an always-on Internet connection for work. I used to be on-call out-of-hours so it needed to work day or night. That's why I have two disparate Internet connections.
on 11-02-2022 12:32
Well had yet another disconnect again
Reset the hub
had a look at the logs (down stream)
1 | 331000000 | 3 | 42 | QAM 256 | 25 |
2 | 139000000 | 5.4 | 43 | QAM 256 | 1 |
3 | 147000000 | 5.3 | 43 | QAM 256 | 2 |
4 | 155000000 | 5.3 | 43 | QAM 256 | 3 |
5 | 163000000 | 5.3 | 43 | QAM 256 | 4 |
6 | 171000000 | 5.1 | 43 | QAM 256 | 5 |
7 | 179000000 | 4.9 | 43 | QAM 256 | 6 |
8 | 187000000 | 5.1 | 43 | QAM 256 | 7 |
9 | 195000000 | 5.1 | 43 | QAM 256 | 8 |
10 | 203000000 | 4.9 | 43 | QAM 256 | 9 |
11 | 211000000 | 5 | 43 | QAM 256 | 10 |
12 | 219000000 | 5 | 43 | QAM 256 | 11 |
13 | 227000000 | 4.8 | 42 | QAM 256 | 12 |
14 | 235000000 | 4.7 | 41 | QAM 256 | 13 |
15 | 243000000 | 4.6 | 41 | QAM 256 | 14 |
16 | 251000000 | 4.3 | 40 | QAM 256 | 15 |
17 | 259000000 | 4.2 | 39 | QAM 256 | 16 |
18 | 267000000 | 4 | 39 | QAM 256 | 17 |
19 | 275000000 | 4.1 | 39 | QAM 256 | 18 |
20 | 283000000 | 3.8 | 40 | QAM 256 | 19 |
21 | 291000000 | 3.7 | 41 | QAM 256 | 20 |
22 | 299000000 | 3.7 | 41 | QAM 256 | 21 |
23 | 307000000 | 3.6 | 42 | QAM 256 | 22 |
24 | 315000000 | 3.4 | 42 | QAM 256 | 23 |
25 | 323000000 | 3.2 | 42 | QAM 256 | 24 |
26 | 371000000 | 3.3 | 42 | QAM 256 | 26 |
27 | 379000000 | 3.3 | 42 | QAM 256 | 27 |
28 | 387000000 | 3.3 | 42 | QAM 256 | 28 |
29 | 395000000 | 3.3 | 42 | QAM 256 | 29 |
30 | 403000000 | 3.2 | 43 | QAM 256 | 30 |
31 | 411000000 | 3.3 | 43 | QAM 256 | 31 |
1 | Locked | 42 | 0 | 2 |
2 | Locked | 43 | 0 | 1 |
3 | Locked | 43 | 0 | 1 |
4 | Locked | 43 | 0 | 1 |
5 | Locked | 43 | 0 | 1 |
6 | Locked | 43 | 0 | 0 |
7 | Locked | 43 | 0 | 1 |
8 | Locked | 43 | 0 | 1 |
9 | Locked | 43 | 0 | 2 |
10 | Locked | 43 | 0 | 2 |
11 | Locked | 43 | 0 | 2 |
12 | Locked | 43 | 0 | 2 |
13 | Locked | 42 | 0 | 2 |
14 | Locked | 41 | 0 | 2 |
15 | Locked | 41 | 0 | 2 |
16 | Locked | 40 | 0 | 1 |
17 | Locked | 39 | 0 | 1 |
18 | Locked | 39 | 0 | 1 |
19 | Locked | 39 | 0 | 3 |
20 | Locked | 40 | 0 | 2 |
21 | Locked | 41 | 0 | 1 |
22 | Locked | 41 | 0 | 2 |
23 | Locked | 42 | 0 | 2 |
24 | Locked | 42 | 0 | 5 |
25 | Locked | 42 | 0 | 4 |
26 | Locked | 42 | 0 | 2 |
27 | Locked | 42 | 0 | 3 |
28 | Locked | 42 | 0 | 6 |
29 | Locked | 42 | 0 | 6 |
30 | Locked | 43 | 0 | 6 |
31 | Locked | 43 | 0 | 5 |
Upstream
1 | 53700000 | 44.5 | 5120 | QPSK | 2 |
2 | 46200000 | 44.5 | 5120 | QPSK | 3 |
3 | 39400000 | 44.5 | 5120 | QPSK | 4 |
4 | 32600000 | 44.5 | 5120 | QPSK | 5 |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
However looking at the network log I get
11-02-2022 12:12:03 | notice | CM-STATUS message sent. Event Type Code: 5; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
11-02-2022 12:11:40 | notice | REGISTRATION COMPLETE - Waiting for Operational status |
11-02-2022 12:11:33 | notice | DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
11-02-2022 12:11:30 | warning | DHCP WARNING - Non-critical field invalid in response ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
11-02-2022 12:11:28 | notice | Honoring MDD; IP provisioning mode = IPv4 |
11-02-2022 12:11:26 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
11-02-2022 12:11:25 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
This appears to be coinciding with exactly when my connection dropped
11-02-2022 13:51 - edited 11-02-2022 13:51
The Upstream is struggling, as the QPSK, should all be 64QAM.
There may be an issue with the VM network or the cables to your house?
Try checking with Area faults on 0800 561 0061 or if you have a VM landline 150 as small local faults are not listed on the VM status page.
on 12-02-2022 17:30
Well had the same issue again at about the same time 4pm-5.30pm. so yet again rang Virgin's frankly ABYSSMAL cs line .
Ran some tests and it appears there's an intermittent fault in my connection (which they completely denied the last time) so once again gave me some checks to do in the house in case it's a fault here (which I've already done at least once before and it was an engineer installation in the first place)
Will give it 24 hours and see if it happens again
on 12-02-2022 17:40
@Axilian It will happen again, I'm afraid. As mentioned above, you have a connection issue whereby the Hub is struggling to 'talk' to the device at the other end of the cable and every so often, gives up and resets itself in a (forlorn) attempt to get a better signal.
If you have checked for any bad connections in the cabling inside the house and not found anything, then this will be an engineer visit to resolve.
Just a thought, but did you have any problems with the previous hub? I would be tempted to look closely at the cable coming from the wall port to the hub itself as that would have been the only thing moved when the hub was swopped. So possibly a dodgy connector or cracked cable there, it all works fine until you disturb it to connect the new hub and, trouble ever since!
on 13-02-2022 10:01
I had a superhub 4 previous to the SH5. Funnily enough this also had issues when it was originally installed though in that case it was due to a too strong signal and the engineer had to put an attentuator in the cable path. Since then however VM have been screwing around with the cable network in my area - as far as I can remember the SH5 was installed prior to this and was fine
on 15-02-2022 10:24
Hi Axilian,
Thank you for reaching out to us here on the Community.
I am sorry to hear of the issues you have been experiencing with the Hub 5, I appreciate this must be frustrating.
I have ran some checks today and the live report is currently not detecting any issues. I can also confirm that there are no known issues showing for your area.
With this in mind, are you able to confirm how your services has been since your last post to us? Also, if you are able to provide the log stats for today, I will be able to cross reference them with what we have on our side.
Thank you
on 18-02-2022 16:15
Currently the modem appears to have settled down. I haven't noticed any disconnects and reboots since the last time I reset the SH5
I've just looked at the logs and now have
Downstream
1 | 331000000 | 2.1 | 42 | QAM 256 | 25 |
2 | 139000000 | 4.1 | 43 | QAM 256 | 1 |
3 | 147000000 | 3.9 | 43 | QAM 256 | 2 |
4 | 155000000 | 3.9 | 43 | QAM 256 | 3 |
5 | 163000000 | 4 | 43 | QAM 256 | 4 |
6 | 171000000 | 3.9 | 43 | QAM 256 | 5 |
7 | 179000000 | 3.6 | 43 | QAM 256 | 6 |
8 | 187000000 | 3.8 | 43 | QAM 256 | 7 |
9 | 195000000 | 4 | 43 | QAM 256 | 8 |
10 | 203000000 | 3.8 | 43 | QAM 256 | 9 |
11 | 211000000 | 3.9 | 43 | QAM 256 | 10 |
12 | 219000000 | 3.9 | 43 | QAM 256 | 11 |
13 | 227000000 | 3.6 | 42 | QAM 256 | 12 |
14 | 235000000 | 3.8 | 41 | QAM 256 | 13 |
15 | 243000000 | 3.6 | 41 | QAM 256 | 14 |
16 | 251000000 | 3.4 | 40 | QAM 256 | 15 |
17 | 259000000 | 3.2 | 39 | QAM 256 | 16 |
18 | 267000000 | 3 | 39 | QAM 256 | 17 |
19 | 275000000 | 3.2 | 40 | QAM 256 | 18 |
20 | 283000000 | 3.1 | 40 | QAM 256 | 19 |
21 | 291000000 | 2.8 | 40 | QAM 256 | 20 |
22 | 299000000 | 2.9 | 41 | QAM 256 | 21 |
23 | 307000000 | 2.7 | 42 | QAM 256 | 22 |
24 | 315000000 | 2.5 | 42 | QAM 256 | 23 |
25 | 323000000 | 2.4 | 42 | QAM 256 | 24 |
26 | 371000000 | 2.6 | 43 | QAM 256 | 26 |
27 | 379000000 | 2.6 | 43 | QAM 256 | 27 |
28 | 387000000 | 2.7 | 43 | QAM 256 | 28 |
29 | 395000000 | 2.8 | 43 | QAM 256 | 29 |
30 | 403000000 | 2.8 | 43 | QAM 256 | 30 |
31 | 411000000 | 2.9 | 43 | QAM 256 | 31 |
1 | Locked | 42 | 225 | 1382 |
2 | Locked | 43 | 256716 | 2132774 |
3 | Locked | 43 | 44839 | 250332 |
4 | Locked | 43 | 41230 | 859969 |
5 | Locked | 43 | 212173 | 2284653 |
6 | Locked | 43 | 2527 | 44569 |
7 | Locked | 43 | 3618 | 49703 |
8 | Locked | 43 | 4714 | 104867 |
9 | Locked | 43 | 4072 | 222251 |
10 | Locked | 43 | 1579 | 57425 |
11 | Locked | 43 | 1944 | 40247 |
12 | Locked | 43 | 1972 | 31629 |
13 | Locked | 42 | 1345 | 67123 |
14 | Locked | 41 | 1300 | 47615 |
15 | Locked | 41 | 241 | 6677 |
16 | Locked | 40 | 750 | 4101 |
17 | Locked | 39 | 707 | 4724 |
18 | Locked | 39 | 688 | 91013 |
19 | Locked | 40 | 622 | 20213 |
20 | Locked | 40 | 588 | 3928 |
21 | Locked | 40 | 430 | 1933 |
22 | Locked | 41 | 328 | 1033 |
23 | Locked | 42 | 288 | 1171 |
24 | Locked | 42 | 232 | 3071 |
25 | Locked | 42 | 317 | 4153 |
26 | Locked | 43 | 104 | 953 |
27 | Locked | 43 | 95 | 1115 |
28 | Locked | 43 | 316 | 930 |
29 | Locked | 43 | 91 | 1047 |
30 | Locked | 43 | 88 | 414 |
31 | Locked | 43 | 54 | 439 |
Upstream
1 | 53700000 | 46.5 | 5120 | QAM 64 | 2 |
2 | 46200000 | 46.5 | 5120 | QAM 64 | 3 |
3 | 39400000 | 46 | 5120 | QAM 64 | 4 |
4 | 32600000 | 46.3 | 5120 | QAM 64 | 5 |
The network log itself is still showing errors
17-02-2022 15:30:51 | error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
14-02-2022 03:31:11 | notice | CM-STATUS message sent. Event Type Code: 5; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
14-02-2022 03:30:58 | notice | REGISTRATION COMPLETE - Waiting for Operational status |
14-02-2022 03:30:52 | notice | DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
14-02-2022 03:30:49 | warning | DHCP WARNING - Non-critical field invalid in response ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
14-02-2022 03:30:49 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
14-02-2022 03:30:47 | notice | Honoring MDD; IP provisioning mode = IPv4 |
14-02-2022 03:30:44 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
14-02-2022 03:30:43 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
14-02-2022 03:30:34 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
on 21-02-2022 14:27
Glad to hear that your getting a better service @Axilian.
I've been looking at our systems for a few days, monitoring it and can see that the disconnections could have been due to the hub trying to make autocorrection to the power levels to keep them in spec, enough of these corrections would be enough to cause an automatic reboot. Have you had any same disconnection issues recently or do you believe the issue has been resolved on your side?
Hopefully the hub has found its 'happy place' and has settled down as you mention.
Let me know if you do have any further issues.
