on 22-08-2021 15:10
joined VM relatively recently, not had major issues until yesterday morning.
superhub 4 suddenly not connecting to anything, doesn’t show as an option in WiFi list and won’t reset to factory settings. I’ve tried turning off and on, tried hard reset for 10/20/60 seconds holding in the reset button on the back, and tried unplugging any Ethernet cables.
No issues in local area per the status checker.
trying to run a test through the VM site just says it’s taking longer to complete than it should then closes out of it.
any ideas?
on 22-08-2021 15:18
on 22-08-2021 15:21
I’d checked via the website and it said no issues. Just called the number in your post and no issues in local area.
on 22-08-2021 15:26
on 22-08-2021 15:31
Outside of 14 days - think it was mid-end July that the kit was delivered and we plugged in.
do you think it actually is connection related? It seems like the hub is just frozen in its state no matter what we do. Could it be the hub instead?
it’s strange because usually with a router I’ve found I can still connect even if there is a problem with the connection, whereas with this it isn’t even showing as if the device exists…
on 22-08-2021 15:35
on 22-08-2021 15:52
Should the solid white light change at all during the reset?
just tried it as you’ve suggested with an earring pin, no change unfortunately…
on 22-08-2021 16:31
on 24-08-2021 16:57
Hi Lucas0224, thanks for getting in touch.
Sorry to hear about the issues you've had with your hub. Looking into it using your forum info I can see that an appointment has already been arranged for you, please keep us updated with the out come of that - or let us know if we can help with anything else.
Tom
