  • 5
m73red
Message 1 of 36
Superhub 3 keeps dropping wired connection
My PC is hard wired directly to my superhub 3 router, several times a day my windows 10 pc, disconnects from the internet.  I have tried different PC's in case it was something within windows 10 and also a new network ethernet cable.  I have also tried wireless connection still with the same outcome.  It generally loses connection for about 20-30 seconds several times a day and then comes back on.  Any ideas what is causing this?
I've logged into the superhub 3 here is the info from the ROUTER STATUS page if that helps?  Please let me know if you need anymore info thanks
Acquired Downstream Channel(Hz)
322750000
Locked
Ranged Upstream Channel(Hz)
39400000
Locked
Provisioning State
Online
Downstream bonded channelsChannel Frequency(Hz) Power(dBmV) SNR(dB) Modulation Channel ID
1322750000138.6256 qam24
23147500000.938.6256 qam23
3306750000138.6256 qam22
4298750000138.9256 qam21
52907500000.738.9256 qam20
62827500000.738.9256 qam19
72747500000.738.6256 qam18
82667500000.738.6256 qam17
92587500000.738.6256 qam16
102507500000.738.9256 qam15
112427500000.938.6256 qam14
12234750000138.9256 qam13
132267500001.238.6256 qam12
142187500001.238.9256 qam11
152107500001.238.6256 qam10
162027500001.438.9256 qam9
171947500001.238.9256 qam8
181867500001.238.9256 qam7
19178750000138.9256 qam6
201707500000.938.6256 qam5
211627500000.738.6256 qam4
221547500000.238.9256 qam3
23146750000038.6256 qam2
24138750000038.6256 qam1
Upstream bonded channelsChannel ID Frequency(Hz) Mode Power(dBmV) Modulation Channel Bandwidth(Hz) Symbol Rate (ksps)
639400000ATDMA49.564 qam64000005120
546200000ATDMA49.564 qam6400000
5120
Operational ConfigurationGeneral Configuration Value
Network access
Enabled
Maximum Number of CPEs
1
Baseline Privacy
Enabled
Docsis Mode
Docsis30
Config file
JKDHSUBsgvca69834ncx
SFID982
Max Traffic Rate230000000
Primary Upstream Service Flow
SFID981
Max Traffic Rate
12700000
Date And Time Error Number Event Description
2018-01-09 11:21:38.0084000500SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-01-09 11:21:38.0084000700RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-01-09 11:21:43.0084020200Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-01-09 11:23:25.0084000500SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-01-09 11:23:25.0084000700RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-01-09 11:23:26.0084000500SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-01-09 11:23:30.0084020200Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-01-09 11:25:39.0084000700RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-01-09 23:54:53.0082000200No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-01-10 22:05:38.0084000700RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-01-14 06:47:36.0068010100DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-01-15 06:50:47.0084000700RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-01-15 10:21:22.0068010100DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-01-15 14:17:40.0068010400DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-01-15 14:17:40.0068010600DHCP Renew - lease parameters tftp file-V0dea97109ea7aa00.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-01-15 21:02:27.0082000200No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-01-16 00:05:16.0084000700RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-01-16 00:30:28.0082000200No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-01-16 03:05:28.0084000700RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 5
m73red
Message 2 of 36
Re: Superhub 3 keeps dropping wired connection
Can anyone help with this please?
  • 5
m73red
Message 3 of 36
bump
  • 12.75K
  • 399
  • 730
Forum Team (Retired) Heather_J
Message 4 of 36
Hi m73red,
Thanks for posting 🙂
Apologies for the connection problems. I've just taken a look and everything looks normal from our end right now. I think it'll be helpful to set up a BQM so we can take a closer look at the performance of your network.
Catch you again soon,
Take care.
Heather_J
  • 8
FoxTC
Message 5 of 36
My LAN connections keeps dropping out ever since I accepted a free upgrade from 150mb to 200mb speed a week ago. Before I was upgraded my system was solid, now my wired connection is dropping out a lot! It’s making it nearly impossible to play on my PS4 online, constantly receiving LAN cable disconnected.
StarWarsFan
Message 6 of 36
I have got the same issue.  Wired connection keeps dropping.  Its a right pain!  @Virgin, is this a firmware issue?
  • 8
FoxTC
Message 7 of 36
I’m sure it’s because I accepted an upgrade, as my connection was solid for years until I went to 200mb. I need to call support but only have a mobile so it’s gonna cost a fortune. I was hoping they might respond to this thread instead.
  • 10.32K
  • 281
  • 591
Forum Team (Retired) Emma_E
Message 8 of 36
Hi FoxTC,
Welcome to the forums, I am sorry to see you had trouble with your connection.
I have taken a look and it seems there was a fibre break ref F005956801. This has now been resolved and the connection looks ok from this side.
How are things looking for you now?
If you are still having trouble let us know and we will be happy to take a look for you.
Take care.
Emma
  • 10.32K
  • 281
  • 591
Message 9 of 36
Hi StarWarsFan,
Welcome to the forums, I am sorry to see you have had similar issues with your connection.
I have taken a look and it seems there is FECS on the connection (noise on the line) I have raised this to networks to investigate further and will let you know once I know more.
Speak to you soon.
Emma
  • 8
FoxTC
Message 10 of 36
Thanks Emma, I am still getting LAN disconnections... I have to play games on WIFI.
