alinnen
Message 1 of 7
Superhub 3 and Poweline Adapters
Hi there,
I've recently had a Superhub 3 installed with the 500 mb/s bundle. After doing some speed tests, it appears that I'm losing of 2/3rds of performance from my bedroom where most of my devices are, compared to standing right next to the modem. There is a particularly bad black spot in my room where a speed test registers 50 mb/s, perhaps my ceiling is lead-lined!
In order to get the sort of performance I'm paying for throughout the house, I've decided to look into getting a powerline adapter. Would this model be compatible with the Superhub 3 and suitable for my new broadband plan? I did some research beforehand and noticed some people were having issues with certain powerline products and the Superhub 3.
https://www.amazon.co.uk/gp/product/B0723C86CX?pf_rd_p=330fbd82-d4fe-42e5-9c16-d4b886747c64&pf_rd_r=...
Thanks in advance.
  • 19.29K
  • 1.68K
  • 4.22K
Message 2 of 7
Re: Superhub 3 and Poweline Adapters
Don't see why not, but don't expect to get close to the advertised speeds, other option could attach a wireless access point onto the hub, since the WiFi on hub3 isn't that great
Click to learn more about VIP
Use Kudos to say thanks
  • 2.57K
  • 99
  • 181
Message 3 of 7
Hi alinnen,
Thanks for posting and welcome to the community 🙂
Sorry to hear of the slow speeds. Have you got a smartphone? If so, can you download the Virgin Media Connect App? When installed, you can do a wireless scan on the app for coverage black spots. You can find out more here
Kind regards,
John_GS
  • 6.15K
  • 470
  • 1.02K
Hero
Message 4 of 7
VM speeds, as with ALL ISPs, are only measurable at the hub via an Ethernet cabled connection, they do not guarantee WiFi speeds.
  • 12.54K
  • 480
  • 1.12K
Message 5 of 7
For something they don't guarantee they do want to sell their boosters.
  • 504
  • 26
  • 107
tonycv51
Rising star
Message 6 of 7
You need a pair and the link you posted said it was a single, though I wonder if it is a listing error as the starter kit appeared to be just a few pounds more but listed lan cables as well (and in my experience they come with these but they could just be cheap cat 5 cables)
The spec ie av1000 is duplex so will be 500 max each way.  The version you've linked does have gigabit ports, but even so would be surprised if you get above 200 and could be quite a bit less
Although you're on 500 does anything actually not work in the bedroom with a speed of 50 on multiple devices?
Sounds like the only way you'd get 500 in the room would be with a wired access point or a good mesh wifi
As VM have suggested you can use the Connect app or other free app to map 2.4 and 5ghz strength over the house to help decide
  • 87
andrewkp
Dialled in
Message 7 of 7
The best powerline adapters are Devolo Magic 2 which are rated to 2400mbs.  They do a good job but you will never see anything like that speed unless they are connected on the same ring (same fuse essentially).  The kit with one base station and two adapters is around £240 and for that money you may be better off sticking the virgin hub into modem mode and buying something like an Asus AC5300.  Putting the hub into modem mode generally can help with other issues also.
However first try putting the phone/pc into airplane mode/wifi off and back on again and see if that helps.  Your speed of 50mbs seems as if it would be on 2.4GHz and I'm wondering if doing this might get it back to the faster but weaker 5GHz band which may marginally improve things.  Also try moving the hub away from the wall and other things like TVs.  Maybe stick it in the middle of the room as an experiment.  On android, iPhone, PCs etc there are various apps to help look for contention and signal strength.  I use WiFi Analyser.
