on 03-09-2021 15:26
We are having problems connecting to the internet with mobiles & tablets. Using Superhub 2. Would it be possible to to get a newer router from VM?
Ian
03-09-2021 15:29 - edited 03-09-2021 15:31
VM will not at the moment simply swap a working Hub for a new one - unless it is demonstrably "broken".
So, is that just over wifi ? What specifically are thee "problems" you are having?
What are connections like on ethernet cable connections?
If you don't know, can you check to help diagnose whether it is just a wifi issue or it could be network connection related?
I have an SH2 but its always been in modem mode and I use my own better quality wireless equipment
on 03-09-2021 15:49
Some days I get a message on the phone could not connect to internet. Reboot the router, then its okay for a few days.
Router connected to pc via ethernet cable.That connection is okay.
Buying my own router and using the SH2 as modem was my intention, but I am getting some access points fitted to extend the range throughout the house and the engineer said try the SH2 with the access points before you buy another router.
I will try that first.
I just thought a newer VM router might improve things.
on 03-09-2021 15:58
on 03-09-2021 16:09
Thanks for the info John.
Getting the house rewired at the mo, so easy enough to have cables anywhere just now.
on 03-09-2021 16:13
