The content you are looking for has been archived. View related content below.
on 15-01-2021 19:16
My hub 3 is showing a red power light instead of the usual white power light. It is solid red but the hub is not overheating and is kept in open space there is a a drop out in wifi connection on all devices through out the day
Answered! Go to Answer
on 16-01-2021 15:08
A warm welcome to our Community Forum Tr4hman and sorry to hear about your Hub light showing red. I've had a look at your details using the information we have on here and can see that everything is okay on our side. However as you've mentioned that the power light is on a solid red, we'll get a replacement Hub sent out to you as it's not normal.
I've arranged for a replacement to be sent out and it should arrive within 5 days and it may pop up on your online account. Please activate it and let us know how it goes.
Lisa
on 15-01-2021 19:24
Are you in Router Mode or Modem Mode ?
In Modem Mode the power light should be magenta.
In Router Mode the power light should be white.
In either Mode the red power light is an indication of over heating and most not be ignored.
Ensure that the Hub is in a well ventilated area and nothing is blocking the vent holes on the sides of the Hub.
If the Hub is in a clear area and is cool to touch and the red power light remains on the Hub must be replaced.
If the Hub is in a clear area and is hot to touch and the red power light remains on the Hub must be replaced.
Do not be fobbed off with "if it is cool it will be OK" or "Just blow a fan over it", this is dangerous advice.
When you go out or retire for the night ensure that the Hub is unplugged from the mains.
The only fix is a replacement Hub.
You can either phone in (08:00 is the best time) or wait on here for a few days (6 to 10 days average) until one of the VM Forum Staff comes along.
on 15-01-2021 19:48
It is in router mode, the hub itself is kept in open space and is slightly warm (not extremely hot) from the top of the hub but the rest is fairly cool and normal. Having read previous forums I think it will need a replacement but it is difficult to get in contact with customer support at the moment so thought id try my luck on here
on 15-01-2021 19:53
on 15-01-2021 21:28
How long is it usually with response time. I will try calling them tomorrow but have feeling will be on hold for atleast an hour! and they probably ask to do the usual reset and reboot which I have already done
on 16-01-2021 15:08
Lisa
on 20-01-2021 15:03
Hi the new hub arrived and set up and lights are now normal but we still getting a lot of drop in connection throughout the day
on 20-01-2021 15:07
on 21-01-2021 11:15
Tested with ethernet connection and it is stable the wifi still drops but ethernet did not drop but all devices on the wifi constantly dropping connection throughout the day.
I am on a m100 fibre package and have 9 devices that are connected to it at the same time so wondering if that would be an issue?
on 21-01-2021 13:45
