TdI
Super hub 3 not working properly with wireless printer
Just switched from BT to Virgin. Every time I want to print I have to turn the printer off and on even though both the printer and hub 3 show they are connected wirelessly. Worked ok before the switch!
  • 19.07K
  • 1.67K
  • 4.18K
Re: Super hub 3 not working properly with wireless printer
if take a look at http://community.virginmedia.com/t5/Networking-and-WiFi/Connecting-WiFi-adaptor-for-air-con/td-p/362... since some devices dont like the combined name for 2.4 and 5ghz
If someone's helped you out say thanks by clicking on the thumbs up on kudos. If someone's solved your problem, why not mark their message as an Accepted Solution, but only do this once issue has been resolved.
TdI
Thanks for the suggestion. Changed the SSID of the 5GHz signal on the router as suggested, but this hasn’t solved the problem. Still need to restart the printer for each print job.
  • 12.75K
  • 398
  • 730
Forum Team (Retired) Heather_J
Hello Tdl,
Sorry for the problems you're having with the connection to your printer. What printer do you use? Have you ensured the software is fully up to date?
Speak soon,
Take care.
Heather_J
TdI
Hi Heather.
My printer is an HP Envy 110e, and I need to print from my iPad via airprint. The iPad says “no airprint printer found” for each new print job. After restarting the printer, it is found immediately.
Both the printer and the router show the printer is connected wirelessly when it can’t be found.
It worked fine before switching from BT last week.
Best Regards.
TdI
HP Envy software is current version!
