  • 91
withnail69
Super hub 3 and Wi-Fi issues
Basically getting really poor speeds, disconnects and drop outs on my MacBook Pro over Wi-Fi. Yet on iPhones speeds were much higher. Trying to ping superhub and half the packets were timing out.
I know the following hasn’t fixed it but it did help... option clicked on Wi-Fi icon on Mac and saw it was 2.4ghz. Thought that’s weird. Logged into router and both 2.4 and 5 ghz were turned on. Turned off 2.4 to force 5 ghz then speeds doubled and drop outs ceased. So my question.... why was I connecting/broadcasting over 2.4 when 5 was available as well. Is there a way to leave both on and connect to 5 ghz?
  • 12.94K
  • 985
  • 2.97K
Re: Super hub 3 and Wi-Fi issues
give them separate ssid's and you then choose which one to connect to - worth turning off smart wifi as well
____________________
Tony
  • 91
withnail69
Done thanks Tony
  • 828
  • 26
  • 47
Thanks for getting in touch withnail69.
Just wanted to check in and see if there has been any improvements since you posted?
Let us know and we will be able to advise further 🙂
Nat
