  • 25
Bern1st
Super Hub or Super Hub3
I am having WiFi problems with it constantly dropping out, even when only in the next room. I am still working with the original Super Hub. Would it be any advantage by upgrading to Super Hub 3. Not having any problems that i can see regarding internet speed, but being a bit of an OAP novice in this department a little advice would be helpful.
  • 9.13K
  • 947
  • 1.43K
Re: Super Hub or Super Hub3
There are many recent threads on here where expert comment has been posted - take a look at the ones below.  You have the original Superhub which is really at museum piece nowadays and you will certainly be better served with a new Hub3 - which works just fine for >95% of customers (internet gamers notwithstanding!).  So I would suggest you call CS and tell them your SH1 hub wifi has stopped working.  They will either just send you out a replacement or organise a technician's visit - who will simply swap it for the Hub3.
If they um and ah and say it looks fine on our tests we cant do that... say ok, hang up and call in the next day with the Hub turned off and say its "dead" it wont power up, and they will have to send a technician.
See Griffins wifi analysis and Hub3 in message 6 of this thread
https://community.virginmedia.com/t5/Networking-and-WiFi/Super-hub-3-Wifi/td-p/3877406
and message 2 of this one
https://community.virginmedia.com/t5/Networking-and-WiFi/Laptop-wifi-intermittent-issues/td-p/388578...
  • 24
Kirston26
In all honesty i'd suggest you put the SH in modem mode, and forget about the issues.
SH3 is one massive issue for gamers
  • 25
Bern1st
Thanks for the help. I will try ringing tomorrow and see what **bleep** they come up with, or they may surprise me and be very positive. haha
  • 25
Bern1st
By putting into modem mode what would i be losing?. does it mean I would need a new router to complement it?
  • 9.13K
  • 947
  • 1.43K
Fingers crossed ! Kirston26 makes a valid point - I myself am in modem mode - but for most customers its not really necessary. If you do have some wifi problems when the Hub3 is installed, just post back here and people will help you sort it.
