on 17-12-2020 21:06
I have an HP Envy 4507 Printer. I wish to use HPs ePrint service. This requires that the printer wakes up when an email is sent to it.
I understand that I need to set a static IP address for the printer on my home network
In The Hub 3 I see that 192.168.0.10 to 192.168.0.254 are assigned to DHCP.
I think I need to give my printer a static IP address of, say, 192.168.1 23.
Can anyone please tell how to do this?
on 18-12-2020 15:36
I have gone into the HP Envy 4507 via IP address 192.168.0.23 and landed in a Utilities webpage. Among the buttons is a create static IP address.
Pressed this and got an IP 192.168.0.249. Logged into this IP and got a text page printed - wonder why this print says URL:http://192.168.223.1?
Tried ePrint; got an email saying ePrint Job Received. But no print and printer did not wake up.
Any advice please?
on 18-12-2020 16:03
rather than using the button to generate a static address, manually configure it (via the same management pages you were on before) to:
IP: 192.168.0.4
subnet mask: 255.255.255.0
default gateway: 192.168.0.1
dns1: 8.8.8.8
dns2: 8.8.4.4
apply the settings and then browse to 192.168.0.4 to confirm the printer is now on the new address.
go to the eprint settings and print out the info page.
on 18-12-2020 20:09
I have set up my printer as you advised. I then send a couple of ePrints from different email address, one of which was my gmail account. Both printed.
However when I tried from my wife's gmail account two try's failed.?
on 18-12-2020 20:47
Double check that the email address you are sending to is correct...
on 20-12-2020 07:39
Yes is was mis-spelt.
Thank you for your advice.
