GrahamScott2
Just joined
Splitter into surge protector extension lead causing interference?
Some of my SNR channels have gone bad recently, and I'm wondering if my set up is the reason?
I have 2 wall sockets, one is powering superhub, other is 6 way extension lead.
On the lead, one of the things going into it is my VM splitter/booster for tv and router, with the coax cable that goes into back of superhub part of it. Is this a big nono? Does the splitter with that coax cable need its own wall socket?
A VM technician set it up like this.
  • 4.2K
  • 280
  • 704
Roger_Gooner
Community elder
Re: Splitter into surge protector extension lead causing interference?
The VM technician has fitted a powered amplifier. Unless you are having a problem with your broadband or TV, it's fine.
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG1008D 8-port gigabit switch, V6
