IneedMySpeed
Speed issues
Hi, got some issues with the bandwidth i think:
It's a wired connection, already tried to reboot, reset the modem, changed and flushed the DNS, did all the tests on a second device.
Here's the router status:
  • 1.01K
  • 143
  • 216
DJ_Shadow1966
Knows their stuff
Re: Speed issues
Hello
This is a power level and / or noise on the line can you check that all of the connectors are hand tight on your hub / TIVO also check that there are no un-terminated connectors on splitters etc.
If the above doesn't resolve the issue then an engineer will be need to resolve the issue.
Regards Mike
I dont work for VirginMedia all opinions are my own.
39 years in IT.
IneedMySpeed
Re: Speed issues
Mike, you mah hero! even if it took me 20 mins to clean up every goddamn jack, join, etc.
Take a look at this beauty:
Thank you for your help mate, have a great day!
