  • 2.82K
  • 190
  • 450
Roger_Gooner
Trouble shooter
Message 11 of 22
Re: Sonoff switch no connecting
No you don't do port forwarding for an IoT device.
The Sonoff is typical of many of these devices in that they support only the 2.4Ghz band. The hub 3.0 needs separate SSIDs for the 2.4GHz and 5GHz bands, do this and connect to the 2.4GHz band.
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG1008D 8-port gigabit switch, V6
  • 1.09K
  • 50
  • 139
Message 12 of 22
Hi Carlo123
How are things looking now
Have you managed to get this resolved?
Gareth_L
  • 8
Carlo123
Message 13 of 22
Hi no I haven't as I cannot seperate the frequencies on my hub 3 as it says that i should not have the same password as the guest network which isn't even turned on
  • 8
Carlo123
Message 14 of 22
And i know that if i can separate 2.4ghz and 5ghz networks then It should work thanks
  • 1.09K
  • 50
  • 139
Message 15 of 22
Hi Carlo123
Have you tried disabling each frequency to see if that helps
Gareth_L
  • 8
Carlo123
Message 16 of 22
Hi yes I have and if I disable 5ghz it works using only the 2.4 .ghz but soon as I turn 5 back on it disconects and stops working
  • 5.72K
  • 627
  • 894
Hero
Message 17 of 22
This should be a doddle.  Do it on a pc/laptop rather than a phone.  When you go into the settings and erase the 2.4 SSID name and change it to anything you want (end it xxxx2) then erase the password and type in any new random one you like and have just created, then repeat it for the 5GHz network (use xxxx5 and the same password you used for the 2), then save/apply changes and away you go.
  • 1.09K
  • 50
  • 139
Message 18 of 22
Hello Carlo123
Have you been able to try what jbrennand has advised
Gareth_L
Brizzol
Message 19 of 22
I have exactly the same issue. New hub as old one broke. Two  Sonoff  devices paired beautifully with everything before new hub. Now won’t work.
 I have separated the 2.4 and 5 into two WiFi networks both work fine. I have paired the Sonoff devices as per instructions, both recognise the 2.4 WiFi and pair to the hub but remain stubbornly off line.
The issue has to be with the hubs setting
  • 1.17K
  • 32
  • 49
Message 20 of 22
Hi Brizzol,
Thank you for your post. I'm sorry to hear this.
Would you be able to disable the 5G connection to see if this helps?
^Martin
