  • 8
Carlo123
Message 1 of 18
Sonoff switch no connecting
Hi I have bought some sonoff wifi switches and they just wont connect I've disabled 5ghz still wont connect driving me nuts anyone able to provide any help?  Super hub 3 if that helps
Thanks allot
  • 602
  • 23
  • 34
Message 2 of 18
Re: Sonoff switch no connecting
Hi Carlo123,
Thanks for your post, and welcome to the community.
I am sorry to hear the new product was not working. Has this changed since your post?
If you need further help please let us know.
Kind regards.
John_GS
  • 8
Carlo123
Message 3 of 18
No not much has changed I have managed to get it to connect of I turn off the 5ghz band but soon as I turn the 5ghz back on it loses connection again
  • 439
  • 18
  • 30
Message 4 of 18
Which model Hub do you currently have Carlo123? If it is a Hub 3.0 these are designed to switch between devices and frequencies depending on which they work on.
Rob
  • 8
Carlo123
Message 5 of 18
Hi I have a hub 3 thanks its still doesn't connect virtually given up now
  • 439
  • 18
  • 30
Message 6 of 18
Do you experience the same problem with any other devices connected to your hub over a wireless connection? If not, have you spoken to Sonoff for further advice?
Rob
  • 8
Carlo123
Message 7 of 18
Hi no everything else works fine including my wifi sockets and wifi light bulbs the sonoff devices are the only ones which do not work right also I have tries separating the 2.4 and 5 ghz frequency but the hub just keeps saying that the passwords can't be the same for both networks
I haventbcintactes sonoff as there likely to tell to separate my frequencies as I know that that does work as it has connected when I disable the 5ghz network but soon as I turned it back on again it lost connection again
Thanks again
  • 439
  • 18
  • 30
Message 8 of 18
Thansk Carlo123, you might need to set up some Port Forwarding rules to enable a smooth connection. I don't have experience with these specific devices, but I'll leave your thread open so that other Community members can comment. Let us know if this helps.
Rob
  • 18.65K
  • 1.62K
  • 4.06K
Message 9 of 18
What model of sonoff since not a make familiar with,  also how you got cabling, have you split the WiFi into different network's
  • 8
Carlo123
Message 10 of 18
Hi it's a sonoff basic switch I've tried sperating the frequencys however whenever I do my uub bounces back and tells me I cant have the same password for both networks 20190206_213918.jpg
