on 11-03-2020 16:52
Hi. Before I start I’ve had a look at the forums and can’t find the answer to this query. Some of my devices are now not connecting to my WiFi. These are a laptop and an android phone.
Earlier today the hub stopped working and after speaking to VM I did a reset using the reset button. They also said they updated it. I have also downloaded the VM Connect App but that says that I’m connected via an unrecognised access point. Now my sons phone won’t connect and my laptop only connects via Ethernet which isn’t practical. Please can someone give me some advice? Is it to do with different Hub settings?
on 11-03-2020 16:59
You may be as well refining your Wi-Fi management, it might not fix your problem but will certainly help keeping track of your Wi-Fi frequencies.
Instructions for Hub 3
Log in to the Hub.
Advanced Settings > Wireless > Security > Add 2 to the 2.4GHz Channel name > Add 5 to the 5 GHz Channel name > Click ‘Apply Changes’
Log out of the Hub.
You will need to reconnect all you Wi-Fi devices some will want to connect to 5Ghz and some to 2.4GHz and some will connect to either.
on 11-03-2020 17:30
Hi. Thanks for the instructions but it’s now telling me that ‘Password should not be the same as guest network’. I don’t have guest network enabled and the password for that is different anyway. This message appears when I have added the 2 and 5 to the wireless names on the security tab.
on 11-03-2020 18:35
on 12-03-2020 11:08
Thank you for help. This worked and my sons phone now connects. However I noticed last night the hub reset itself twice. I’m not sure now why it’s doing this. Do I need a new one? I occasionally work from home and can’t have it stopping working every hour.
on 12-03-2020 13:32
on 04-08-2020 17:01
Wow. I've been looking all over for a fix and now eventually found it. Thanks so much.
on 24-07-2021 10:19
How do you log into hub? Do you have to use cable?
on 24-07-2021 13:45
Hi @Chrisstowell,
Thanks for getting in touch - are you able to expand on what you're trying to do when logging in for the hub?
Let us know and we'll do our best to advise.
Kind regards,
