Solid red light
Laineyb123
Our Hub has a constant solid red light instead of a white one, has been around 3 weeks, have checked connections, reset many times, isn’t overheating .. Any ideas?
1 ACCEPTED SOLUTION
Accepted Solutions
Anonymous
Not applicable
Assuming it is a hub 3 and isn't in modem mode then you need a replacement hub via a VM engineer.
Keep the hub in a ventilated position and consider turning it off overnight in the meantime.
3 REPLIES 3
Anonymous
Not applicable
Carley_S
Hi Laineyb123,
Welcome to the community.
Sorry to hear that you're having issues with your Hub at this time. Please join me on private message so I can locate your account and book you the earliest available tech. You can see your private messages at the top of the page, in the envelope icon.
Here to help 🙂
Virgin Media Forums Agent
Carley
Carley_S
Thanks so much for your private message Laineyb123, I have now booked you a visit for your hub issue – you can check the date and time via your online account here. If you have any issues with accessing your online account or unable to see your visit, please do let us know and we’ll pop you a message to confirm.
There will be no charge for this visit unless:
•    The technician diagnoses the faults as not being caused by our network/equipment
•    The technician discovers that the fault or problem relates to your equipment
•    The technician discovers that the fault or problem relates to any system that we are not responsible for
The technician will confirm during their visit if any of these instances apply, and if so, a £25 charge will be applied to your account.
Please ensure there is someone over the age of 18 present at the time of the visit. If you need to change or cancel your appointment you can do this online or via the MyVM app by 4pm the day before the appointment.
If you do miss an agreed appointment for any reason, a £25 missed appointment charge will be applied to your account on the day of the appointment.
Here to help 🙂
Carley
