on 10-01-2022 22:24
Hi all - the power light on my super hub 3 is showing solid red and all the Ethernet connected devices are no longer responsive. The router hasn’t moved and isn’t warm, usual reset hasn’t changed things…any ideas?
on 10-01-2022 22:56
Are you in modem mode?
on 11-01-2022 06:41
Thanks Gary yes it’s in modem mode
on 11-01-2022 08:18
Hi pierre214,
Thank you for your post and welcome to the community.
I'm very sorry to hear about the issue you're having with your broadband.
I have been able to locate your account on our side and can see you have a reported fault in your area.
This is SNR fault. The reference for this is: F009522266. The estimated fix date is: 13 JAN 2022 15:00.
Can you confirm for how long the red light has been showing on the hub?
^Martin
on 11-01-2022 08:20
If you’re in modem mode the hub3 shows a permanent red/magenta light all the time anyway
on 18-01-2022 19:04
Thanks a lot guys, this is now resolved.
best,
peter
on 21-01-2022 10:41
