on 26-04-2022 15:22
I'm also experiencing the same issue with the red light on my Hub 3.
The broadband seem to be working fine but now and then it drops out. How I get this fixed?
on 26-04-2022 15:26
on 26-04-2022 15:47
Hi there @Sinbad786
Than you so much for your first post to our community forums and welcome to the team! It's great to have you here!
Can I just check, is the light continuously red? Have you also tried a full factory reset at all?
To do this push a pen etc into the 'reset' hole at the back of the Hub and hold it in for 20 seconds.
Thank you.
