Solid red light and WiFi errors
My hub 3.0 has had a permanent solid red light at the bottom for a long time. It is not overheating and although WiFi appears fine ( if a little slow) the diagnostic tool suggests there is an error. Please can anyone advise?
  • 12.14K
  • 943
  • 1.56K
Re: Solid red light and WiFi errors
When in Router Mode the red power light is an indication of over heating and most not be ignored.
Do not be fobbed off with "if it is cool it will be OK" or "Just blow a fan over it", this is dangerous advice.
When you go out or retire for the night ensure that the Hub is unplugged from the mains.
The only fix is a replacement Hub.
You can either phone in (08:00 is the best time) or wait on here for a few days (6 to 7 days average) until one of the VM Forum Staff comes along.
Mike Robinson
  • 4.46K
  • 755
  • 1.82K
Have you tried a reset of the Hub?  That can sometimes sort these issues out.
If that doesn't fix it the hub will need replacing.
