on 12-05-2023 14:07
Hi, I have had a solid red light on my Hub for the last 2/3 weeks, have tried to reset/turn on off and nothing. Coincided with poor broadband at home?
Answered! Go to Answer
on 12-05-2023 14:13
Call it in as a fault. It will need replacing by an engineer.
on 12-05-2023 14:13
on 12-05-2023 16:34
Yes the hub probably needs replacing, but is nothing to do with your poor broadband. This problem will need investigating when you have a new hub.
on 12-05-2023 17:07
Hi @Phercater
Thanks for posting on our community forum and so sorry to hear about the issue with your broadband hub.
I am going to drop you a private message now to collect some more information and investigate further. Keep an eye on your inbox for a message from myself.
