on 15-06-2022 20:11
My router is showing a constant red light since install last wk. Ive restarted, reset and switched between modem and router but light always red. Its got plenty of space and ventilation and not hot to touch. Does it need replacing?
on 15-06-2022 20:30
Hello @egorm,
Welcome back, thanks for posting.
I am sorry for the issues with your Hub.
I will send you a private message now, so I can arrange a replacement for you.
Many thanks,
