on 25-10-2022 20:01
We run the Hub 3 router in mode mode. After it was mistakenly power cycled it won’t reboot into modem mode, normally indicated by a solid magenta power light. Instead the power light remains solid green and the green up and down arrows flash. Rebooted it a couple of times now and no difference. Checked all the connections and they are done up tight. No faults on the network in our area. Diagnostics check says there is a problem connecting to the hub. Any advice gratefully received.
on 25-10-2022 21:03
on 28-10-2022 08:04
Morning skibuddy,
Thanks for posting and sorry to hear you've not had the best experience cancelling the technician visit. You should be able to do this via your online account, apologies this wasn't showing.
Glad to hear you've been able to sort things in the end.
Alex_Rm
