on 24-11-2021 13:17
The Hub 3 is such a frustrating piece of crap. Why, can't VM post proper reset instructions anywhere publically? Why does resetting the Hub 3.0 lead to creating your own password, directing you then back to the login page, to then advise you that "someone else is still logged into your router" ergo blocking the only user who wants to access from actually accessing it and tuning their setting to their needs? And it's glaringly obvious wifi a nest system is offered to improve wifi coverage, even if they try and scam a premium for something that's supposed to be included in the package (you know, a usable wifi connection!)
It's bad enough I keep getting lied to by customer services (pretty sure this O2 merger has put maxed out capacity and is causing them all more stress!) and it takes an hour to ensure any human actually understands the nature of the issue (longer if they repeatedly try and sell you something that's already included in your package; see Volt benefits and try and actually get an honest response, with confirmation without giving yourself a migraine. I dare you!).
on 24-11-2021 13:21
Most ISP Routers will not give full house coverage, as it's impossible to predict the wifi problems. VM have the Pods, BT have their disks and Sky have their mini boxes. It's just the way wifi works, and perhaps user expectations are set too high?
on 24-11-2021 14:24
User expectations are only set so high because of how the ISPs market their products. They only have themselves to blame!
I, for one, am hoping with the Hub5 I can my USG router. And if the Wifi6 it has isn't man enough then I will have to keep my existing unifi wireless in place. Maybe I'll need it anyway as I need to bounce a mesh up for my ChromeCast on my bedroom TV. Sadly I didn't have the foresight that I could play games via my Chomecast on stadia, otherwise I would have wired ethernet upto the bedrooms when we re-plastered the house.
on 24-11-2021 14:57
