SmartThings Station (hub) and Hub 5
themainliner
I've got the new SmartThings Station (hub) and I can't connect through my Hub 5 from the SmartThings app on my Samsung phone. I cannot connect to Wi-Fi with the phone fine. I can connect tablets and laptops to the Hub Wi-Fi, it only appears to be the SmartThings Station that is causing issues. The Station is underneath the phone and both are a metre from the Hub 5.
Open to troubleshooting suggestions and/or AP suggestion (I read that an N300(?) works in this role).
1 ACCEPTED SOLUTION
Accepted Solutions
The new Hub 5 ax wifi 6 protocol seems to be causing issues for some, mainly older, IoT devices.  It has been noted the TP-LINK RE450 AC1750 Buy TP-Link AC1750 Dual Band Wi-Fi Range Extender & Booster | Wi-Fi boosters | Argos seems to work, in that is can connect to the Hub 5 and also older IoT devices, so acting as a "bridge" between the two wifi protocols.
4 REPLIES 4
You should of got a better router
Perhaps you'd like to suggest one as I'm only using the one my ISP sent me at this point smart guy. Also, it's "should've"...
I know nothing about the Samsung box you have   But a new router or Mesh from a reputable networking company would almost certainly solve all the issues.  We can recommend many but it rather depends on several factors - size/layout/build of property, what features do you want (wifi6, etc), Mesh capable, and of course budget.
Look at offerings from TP-Link, Asus, Netgear, etc.
£40-100 will get a good introductory  model (below) whilst pay more for top end gear or a Mesh..
https://www.amazon.co.uk/Archer-C6-Wireless-Supports-Parental/dp/B07L5YRYF4/
https://www.amazon.co.uk/TP-Link-OneMeshTM-HomeShield-Archer-AX72/dp/B09VPTT9GY/
