  • 16
  • 10
Kaleem71
Smart wifi
Is it better to disable smart wifi on the hub 3.0 wifi settings? Want my phone to connect to 2.4ghz but only connected to 5ghz.
  • 13.75K
  • 1.45K
  • 2.91K
Re: Smart wifi
You can rename the networks without turning off Smart WiFi. But the current update will periodically reset the hub to factory settings which will wipe out any changes you make. I have had to set my hub up from scratch 3 times now. Hopefully the next update to the firmware will fix the issue.
Cable customer since 1993. Services: FH TV, Sky Sports & Movies (2xV6), Talk Anytime Phone, VIVID 350, Virgin PAYG Mobile
