Smart plugs and hub 4
PhilipF
Superfast
Resolved most issues, now kasa tp link light and plugs will not connect, I understand its an issue with the smart devices is unable to connect to to 2.4h band. I have tried the adjust settings on hub gui as advised on here. Anyone got other clear solutions. Otherwise any 5hz smart plugs available anywhere seem rare.
1 ACCEPTED SOLUTION
Accepted Solutions
It goes for any WiFi device if you change the VM hub then the SSID name/s will change. The easiest solution is to just rename the SSID name/s in the new hubs settings to the old name/s.
3 REPLIES 3
PhilipF
Superfast
All sorted reset plugs via kasa app need to point at new ssid, shame not mentioned anywhere on or off forum.
Travis_M
Hi @PhilipF
Great to hear you've managed to resolve this issue!
Have a great weekend.
Travis_M
