on 01-07-2022 00:17
Hi everyone, does anyone have any idea why I can’t connect most of my smart equipment to my hub 4? I’m aware of having the hub set to 2.4ghz and while I can connect 1 or 2 things, most of the equipment will not pick up the wi fi. Everything is close to the hub for setup but no joy at all. I had no such issues with the hub 3, can I switch to the hub 3 after having the 4 fitted?
this isn’t just for laziness, I’m blind and rely on Alexa a lot to control stuff plus it keeps my electricity bill down.
on 01-07-2022 20:29
Hi Sparky3366
Thanks for posting. With this, have you split the bands on the hub? We don't recommend doing so due to the intelligent WiFi in the hub, however I am aware some smart appliances need them to be split.
Let me know. Best,
on 03-07-2022 12:37
Hi, thanks for your reply…yes I’ve split the bands and then restarted my iPad.
heeeeelp!
on 05-07-2022 14:00
My apologies that splitting the bands have not worked for connecting your smart devices.
If splitting the bands has not forces the connection to the 2.4ghz - the only other option is to disable the 5ghz band temporarily and let the devices connect to the only available 2.4ghz network. Once the devices have connected, you can then enable the 5ghz band again. If this also does not work, I would suggest speaking with the manufacturers or forums of the 3rd party devices that you are having issues connecting to the network. I have check the systems at my side and see no issues with the service.
