on 02-08-2021 15:08
Hello we are a house of 4 people. We have a hub 4 connected to a 10 port TP link switch where the far right socket is connected to the ACT/Link port and the rest act as extensions.
We have been struggling to get wired ethernet in the rooms and in the course of troubleshooting our wired speed seems to have dropped substantially to only 9mb after reboots turnings off and on and now the wired ethernet is worse than it was.
The hub is in a little cupboard near the front door so its not near any other devices and there are no virgin faults in the area.
A router diagnostic revealed that various devices in the house have a low signal so my housemate is buying an electrical signal booster.
A friend has suggested checking for channel interference but im not confident enough in changing the channel settings.
Any suggestions gratefully accepted as 9mb for wired ethernet with a 200mb package is cleary not good enough. Thanks in advance all
Answered! Go to Answer
on 02-08-2021 16:22
@legacy1 wrote:Remove the TP link switch and reboot the hub
Connect a PC to the hub and do a speed test check the link speed in windows networkingHow to determine Wi-Fi and Ethernet connection speed on Windows 10 | Windows Central
Appreciate this has been said a lot, but as it's a Hub 4, a reminder that the best speed test to use when in router mode is www.samknows.com/realspeed as it will do a test to the Hub and then a separate test through to the home networking device.
02-08-2021 16:09 - edited 02-08-2021 16:10
on 02-08-2021 16:22
on 12-08-2021 20:45
Cheers dude my housemates are now saying the internet is a lot better. I heard each port has its own collision domain but maybe there were collisions causing the inconsistent speed.
