on 05-01-2022 19:19
Good evening,
In last few days I tried to find the issue of occasionally slow connections.
Netflix buffering slowly, google has a long delay to searching or start loading pages.
Hub has reset, switch it off for 1 min. The test can't be preformed as is show "unknown issue"
In ookla speed results gives me maximum 50% of speed (depending of server)
Any advice what can I do?
on 05-01-2022 19:25
05-01-2022 19:51 - edited 05-01-2022 19:52
I have connected TV to Netflix and it sometimes has delays with buffering.
My phone and laptop is wireless.
It happens only occasionally, when it drop. But in my 200Mbps broadband I have speed under 50Mbps now. (checked in android phone)
on 05-01-2022 20:26
@MaoVi wrote:I have connected TV to Netflix and it sometimes has delays with buffering.
You need to test with a wired device. Wireless speeds and connectivity are not supported and are not reliable nor accurate.
on 05-01-2022 20:44
In the past I had a full speed at any server in ookla at any device. So it not make sense for me.
on 05-01-2022 22:10
@MaoVi wrote:In the past I had a full speed at any server in ookla at any device. So it not make sense for me.
So test with a wired device and see what speeds you get
on 08-01-2022 11:18
Hi MaoVi
Thanks for posting. Sorry to hear of the lower than expected speeds. I've ran a check today and can see no outages and your levels are fine. Congestion/SNR (signal to noise ratio) are fine as well. The WiFi is showing a few issues however. Have you got a smartphone? If so, please download the Virgin Media Connect App and then when downloaded, you'll be able to run a wireless scan in the property. This will identify any coverage blackspots, optimise where possible and also advise if you need a Pod or not.
Please could you also run a wired speedtest at speedtest.net via a laptop/PC if possible, connected via Ethernet? This will enable us to see if it's just a WiFi issue or an overall broadband speed issue.
Best,
