on 08-04-2022 17:15
For months now we've been having issues where the signal seems to drop and becomes very slow or often cuts out entirely. The issue seemed to be resolved but now has become even worse - doesn't cut out for as long (only between 30 seconds and a couple of minuted) but has become much more frequent to the point that working from home and even trying to make WhatsApp calls has become very hard and stressful.
I've done the area test and says no problems, then the personal test says that there is an intermittent issue but doesn't say what is wrong, says to check back in 24 hours. I did this a couple of days ago, check back and it just starts from the beginning...
Please can someone help sort this out because our WIFI's becoming almost unusable.
Shea
on 08-04-2022 17:16
on 08-04-2022 17:20
Hi John,
Thanks for your reply. All devices are connected wirelessly - unfortunately I do not own any devices that support ethernet so cannot check. The hub is model 3.0 and it shows just the solid white light even while the connection drops.
Shea
on 09-04-2022 15:12
on 12-04-2022 08:44
Hi there @sheachallis
Thank you so much for your post to our community forums and welcome to the team! It's so great to have you on board!
I'm so sorry to hear that you are facing these issues and thank you so much to @jbrennand for their help on this so far!
Are you able to connect via an Ethernet cable and run a test as advised?
Can you post also your Hub status and logs? How to do this;
• Copy/paste the data from each of the tabs as text into a 'REPLY' as opposed to 'QUICK REPLY'. Please do not include your MAC address.
Also, set up a 'Broadband Quality Monitor'. This will monitor the state of your connection and record any network dropouts etc.
Give it a while to gather data and then click 'Share Live graph' and paste the 'Direct Link' into the forum.
Thank you!
