on 08-04-2022 14:15
Hi All,
Experiencing some technical difficulties with my WiFi, Noticing that it can drop in speed greatly - or just completely fall off.
Done several Hard resets. Done several soft resets. Unplugged the router and replugged the Router, the issue has been going on for at least a month.
I did just a little investigation and noticed this in my network logs. Please tell me If i need to include anything else
08/04/2022 12:58:6 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
07/04/2022 14:59:22 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/01/1970 00:01:39 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
07/04/2022 13:29:54 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
07/04/2022 13:16:13 | Warning! | LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
07/04/2022 13:13:20 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
07/04/2022 12:18:24 | Warning! | LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
07/04/2022 10:37:1 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
07/04/2022 10:37:1 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
07/04/2022 09:00:15 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
06/04/2022 20:51:38 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
06/04/2022 20:10:3 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
06/04/2022 17:36:14 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
06/04/2022 17:36:14 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
06/04/2022 16:55:42 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
06/04/2022 16:55:42 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
06/04/2022 11:51:56 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
06/04/2022 11:16:30 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
06/04/2022 10:27:8 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
06/04/2022 09:47:13 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
1 | 139000000 | 8.4 | 38 | 256 qam | 1 |
2 | 147000000 | 8.3 | 38 | 256 qam | 2 |
3 | 155000000 | 8 | 38 | 256 qam | 3 |
4 | 163000000 | 7.8 | 38 | 256 qam | 4 |
5 | 171000000 | 7.8 | 38 | 256 qam | 5 |
6 | 179000000 | 7.5 | 38 | 256 qam | 6 |
7 | 187000000 | 7.3 | 38 | 256 qam | 7 |
8 | 195000000 | 7 | 38 | 256 qam | 8 |
9 | 203000000 | 6.5 | 38 | 256 qam | 9 |
10 | 211000000 | 6 | 38 | 256 qam | 10 |
11 | 219000000 | 5.6 | 38 | 256 qam | 11 |
12 | 227000000 | 4.9 | 38 | 256 qam | 12 |
13 | 235000000 | 4 | 38 | 256 qam | 13 |
14 | 243000000 | 3.7 | 38 | 256 qam | 14 |
15 | 251000000 | 4 | 38 | 256 qam | 15 |
16 | 259000000 | 4.3 | 38 | 256 qam | 16 |
17 | 267000000 | 4.5 | 38 | 256 qam | 17 |
18 | 275000000 | 4.9 | 38 | 256 qam | 18 |
19 | 283000000 | 5 | 38 | 256 qam | 19 |
20 | 291000000 | 5.3 | 38 | 256 qam | 20 |
21 | 299000000 | 5.4 | 38 | 256 qam | 21 |
22 | 307000000 | 5.5 | 38 | 256 qam | 22 |
23 | 315000000 | 5.8 | 40 | 256 qam | 23 |
24 | 323000000 | 6 | 40 | 256 qam | 24 |
1 | 53700000 | 41.5 | 5120 | 64 qam | 2 |
2 | 60300000 | 42 | 5120 | 64 qam | 1 |
3 | 46200000 | 41 | 5120 | 64 qam | 3 |
4 | 39400000 | 40.5 | 5120 | 64 qam | 4 |
on 08-04-2022 14:27
08-04-2022 14:37 - edited 08-04-2022 15:09
Sadly the down one won't become a table and provided the Upstream one as well. Lights seem to be a yellowish constant even when the issues occur
There are no devices in the household connected with ethernet cables other than the router as the house I live in only has the one data port.
ChannelLocked StatusRxMER (dB)Pre RS ErrorsPost RS Errors1Locked38.951314002Locked38.942514933Locked38.942813594Locked38.636415845Locked38.939513856Locked38.634817217Locked38.935316498Locked38.937116169Locked38.6384150510Locked38.9354150511Locked38.9409156812Locked38.6403136413Locked38.9463147114Locked38.9446129715Locked38.9414137216Locked38.9350133017Locked38.9357143418Locked38.9375148119Locked38.9297162320Locked38.9327171721Locked38.9380142822Locked38.9338135823Locked40.3305157824Locked40.32971591
1 | ATDMA | 0 | 0 | 1 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
*Edit* When this starts happening it affects ALL connected wifi devices - not just one specific one
on 08-04-2022 15:07
on 08-04-2022 18:29
You can see 1 spike for today which matches what occurred today - though it probably missed when I spiked before that since I hadn't set it up by then.
on 08-04-2022 19:01
on 12-04-2022 08:43
HI DaveZen, thanks for the message and sorry to hear that you are having issue with the broadband speed and Wi-Fi. Can you confirm if you have done what jbrennand has suggested and if this has resolved the issue for you? Please let us know if you still require assistance with this and i will happy to assist where possible. - Chris
on 12-04-2022 20:09
No problem at all.
I have done what Jbrenner has suggested - and it has made it slightly more stable. But Noticed today that it dropped again.
https://www.thinkbroadband.com/broadband/monitoring/quality/share/7b0a7171cd2401df768b83cbba3b124e8d...
https://www.thinkbroadband.com/broadband/monitoring/quality/share/818976d6d018d3659e5f89b7e076ec5b21...
https://www.thinkbroadband.com/broadband/monitoring/quality/share/d76a0f2d2a57c2e931a63aa4f8fa5159c09c0f01-11-04-2022
https://www.thinkbroadband.com/broadband/monitoring/quality/share/6cd143009c946d3eb43dd1c5e45293d569...
Sorry for the formatting - These are the 4 days on bandwidth tracking.
Pre Errors are all back to 1000's and Posts errors are all 4000+
on 15-04-2022 10:23
Hi @DaveZen
Thanks for getting back to us. Sorry to hear you are still experiencing connection drops. I would like to run diagnostics on our systems to see what may be causing this. I was unable to locate your account from the details provided, so I shall send you a private message now.
Best wishes,
Serena
on 20-04-2022 13:27
Additional days of broadband monitoring as requested
Quality is random - Somedays are perfect, SOmetimes only one drop and others - constant dropping within an hour
