I am suffering a few different issues.
I am trying to introduce an Etherrnet Switch into my network to allow ethernet connections upstairs from running one single cable. The Etherney switch is Gigabit, TL-SG105S is the model number. I am only getting 80MB when my wifi runs around 400MB. I have tried to remove the switch from the network and i only get around 80MB when running a Cat5E cable, circa 20metres from Hub 3 to PC which also has Gigabit Ethernet, Realtech PCIe GBE Controller is the name.
When i look at the network name, it states that the Ethernet is plugged into VMxxxx_EXT.
VM_xxxx_EXT is an entended netwrok which was set up when i was previously using a Wifi Extender. That WIFI extender is now unplugged and back in the box. I am therefore unsure why my PC which is cabled to the router;
1 - Thinks i am connected to an old wif extended network.
2 - Giving me 80mb speeds.
Any advise would be greatly appreciated.
