on 28-10-2021 13:55
I'm having issues whereby my SuperHub 3 router is passing super slow, ~5Mb, via ethernet yet ~300Mb via Wifi.
I have a google mesh setup with the hub running in router mode and work has became increasingly more tiresome due to the speeds so i disconnected the whole mesh system and back to the SuperHub only.
Things i've tried;
I've only spent an hour and a half on Virgin support (helpdesk lvl 1, helpdesk lvl 2, gadget team, broadband team, senior broadband team) - to solely have a ticket raised to check my internet performance for 30 days for Ofcom (which won't show anyway as it is the ethernet speed which is slow which they couldn't see on their end).
Can anyone help? I was thinking i needed a replacement router but told multiple times on the phone that would also impact the Wifi (surely they run on different cards and that's not the case?)
on 28-10-2021 14:54
on 28-10-2021 18:31
Thank you very much for the reply!
I'm on 350Mb package so the Wifi is spot on!
Below are the results from modem mode (tried on another laptop - and similar numbers)
Browser | Latency | Jitter | Download | Upload |
Chrome | 21.3 ms | 2.50 ms | 5.63 Mbps | 4.21 Mbps |
Edge | 21.6 ms | 3.04 ms | 5.71 Mbps | 4.20 Mbps |
Will boot into networking mode now and give that a go too
on 28-10-2021 18:41
Please also see results below for safe mode with networking on - pretty much similar;
Chrome | 23.3 ms | 3.70 ms | 5.03 Mbps | 4.21 Mbps |
Edge | 20.4 ms | 2.37 ms | 5.73 Mbps | 4.50 Mbps |
28-10-2021 20:42 - edited 28-10-2021 20:48
Might be the NIC you have or software it has slowing you down.
or a bad cable try a new CAT6 one
on 28-10-2021 22:32
Thank you
Tried it with other cables i had lying about and results seem to be very similar;
cat 5 cable;
Chrome | 21.6 ms | 2.11 ms | 5.73 Mbps | 4.89 Mbps |
Edge | 22.1 ms | 2.45 ms | 5.53 Mbps | 5.05 Mbps |
cat 5e cable;
Chrome | 21.6 ms | 2.24 ms | 5.73 Mbps | 4.82 Mbps |
Edge | 21.5 ms | 2.39 ms | 5.77 Mbps | 5.06 Mbps |
on 28-10-2021 22:33
Forgot to note also this issue is with two separate laptops in the house (~8 years difference in age) - though are both Dell
on 28-10-2021 22:38
on 28-10-2021 22:49
Dell Inspiron 7548
Dell Lattitude 5410
on 28-10-2021 23:11
