Significant latency and connection problems
mrobinson97
Hi all, for the past month at least I have been experiencing lag spikes.
It's most noticeable during video calls for work where I will be disconnected for 20 - 30 seconds and in online gaming, where the ping spikes and I get booted from the game. There's no faults in my area according to the app.
This happens on all wired and wireless devices seemingly.
I have been trying to troubleshoot this for a week or so and have discovered the BQM tool;
Now I'm no expert, but this cannot be a normal quality of service. I have been on with VM tech support but I don't think resetting my Hub another time is going to help with this.
Any advise is greatly appreciated!
1 ACCEPTED SOLUTION
Accepted Solutions
mrobinson97
Update (Final):
The issue has been resolved by the 2nd Technician visit. I have delayed updating here in case it was a temporary fix, but my recent BQM is much improved and I haven't experienced any of the issues I was seeing prior to this fix.
https://www.thinkbroadband.com/broadband/monitoring/quality/share/abe4f4b39d2e14bccf172353081082ee68...
So the technician this time basically replaced everything but the Hub, including the converter that @Seph suggested along with moving the port in the cabinet.
Technician this time was very good, he ran diagnostics after each replacement and wanted to ensure the issue was resolved before leaving!
Thanks for your help @Seph, you have helped me learn a few things around network diagnostics that I hope I wont have to use any time soon!
25 REPLIES 25
Sephiroth
Your upstream/downstream stats and Network Log from the Hub's user interface would be helpful in helping to diagnose the problem.  The BQM is unusual (compared with others) in that the greatesy latency appears on the downstream (the yellow bit) yet the packet loss often means an upstream problem.  If both are suffering, it may be nothing more than a loose coax cable.
Also do please provide a postcode and if you have an opportunity to check with neighbours, are they experiencing problems?
Thanks for the reply Seph!
Checking all connections on my end looks ok. Will still triple check this though.
My Postcode is BT191AN.
And the Network log is basically these warning & critical entries repeated indefinitely:
02/09/2024 08:58:18noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/09/2024 08:53:7Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/09/2024 08:53:3criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/09/2024 08:33:41Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
If you can also provided the upstream & downstream power levels for completeness.  The postcode was requested so that it might be tied in with what others might report.  In this case, not yet.
The Network Log would have more in it, imo, if there were to be any dodgy power/noise levels.  But we'll see when you post the stats.  If upstream & downstream are showing issues in the BQM, then it may be no more than a coax cable coming loose - either in your house or in the feed box on the outside of your property.
Also the neighbours:  similar problems?  Important to know this because it then raises the stakes with VM.
Below are the Upstream & Downstream stats:
Neighbours with VM that I've been able to contact haven't noticed any significant issues with their service.
Sephiroth
Thanks.  There's a clue in the stats.  The downstream power& SNR are in spec but low.  The upstream power is fine (albeit low - but that power level is commanded from the VM end).  I suspect the following:
1.  Your house is situated near to the street cabinet serving your broadband;
2.  There is an attenuator attached to the rear of your Hub 3.  This might now be a noise source.
If you do have an attenuator, please remove it and tighten everything up again.  Then post your stats again.  I would like to see the downstream SNR rise to around 39/40 and the power level rising to present + whatever the attenuator says as a number.
PLEASE NOTE:  There is a 2nd page of downstream stats showing the number of uncorrected errors (as in lost packets).  We should see the before/after data.
Keep us posted.  If this solves it, no need for the round-the-houses you might suffer if the VM bods say everything is in spec!
mrobinson97
So the 2nd page of Downstream stats for completeness:
ChannelLocked StatusRxMERPre RS ErrorsPost RS Errors
1Locked38.95912633716
2Locked38.6757413052
3Locked37.6793265926
4Locked37.36277125073
5Locked38.94524244232
6Locked38.63631143336
7Locked38.63520941708
8Locked38.63503535930
9Locked38.63577346264
10Locked38.63031055778
11Locked38.6594979593
12Locked38.91110978335
13Locked38.63858748478
14Locked38.94765131861
15Locked38.64557010865
16Locked38.64085810717
17Locked38.664619031
18Locked38.6154014273
19Locked38.6159910960
20Locked38.6165611062
21Locked38.6176511680
22Locked38.6293910697
23Locked38.9263511095
There is a device on the rear of the hub, although it's a Wideband Equaliser rather than attenuator. A quick google tells me that the two effectively have opposite functions, so I'm hesitant to remove it for now.
Happy to remove it and see what happens, if you also think a Equaliser could be a source of noise opposed to an attenuator?
Edited: Replaced Image of downstream stats with table
Sephiroth
You can safely remove the equaliser.  It's a passive device but it could break down internally.  The worst that can happen when you connect it all back up is that your power levels go out of spec - that will affect performance and damage nothing.
Your stats haven't been approved by the mods so I can't see them.  Are there any uncorrectable errors?
Sephiroth
I can see them now.  It's exactly as I suspected.  The downstream is in serious trouble.  Those numbers are lost packets.  I hope that removing the equaliser removes the problem.  If not, we'll talk about that.
mrobinson97
Will give it a try and report back shortly!
Apologies! I'll add it as a table instead:
The Post RS Errors look to be v high.
