  • 8
Message 1 of 15
Short connection drop, even on wired connection
My Router was installed on 16/10/20. 50Mb/s, 2 desktops at most.
Everything seems fine, but even on wired connection my Desktop gets short connection drops every 5 minutes or so.
I have tried several cables (including the CAT6e that virgin provided!)
I have already reset pin the router.
Ive updated all windows updates and all ethernet drivers.
This was not a problem at my previous home (also on virgin)
  • 24.99K
  • 1.44K
  • 3.18K
Message 2 of 15
Re: Short connection drop, even on wired connection
Are you wired direct to the hub or via a switch/powerline adaptor.
  • 8
Message 3 of 15
I am directly wired.
And i have also tried to use a switch into it.
The problem occurs on all setups. As the problem is intermittent it is hard to tell what the exact cause it.
It seems to be most frequent during peak hours, but this should not be relevant for 2 PC's on 50Mb/s connection.
  • 24.99K
  • 1.44K
  • 3.18K
Message 4 of 15
Post the network, upstream and downstream logs from the hubs admin pages
  • 8
Message 5 of 15
Down
1331000000-1.537256 qam25
2203000000-1.237256 qam9
3211000000-1.537256 qam10
4219000000-2.237256 qam11
5227000000-4.935256 qam12
6235000000-3.236256 qam13
7243000000-237256 qam14
8251000000-1.737256 qam15
9259000000-1.537256 qam16
10267000000-1.437256 qam17
11275000000-1.237256 qam18
12283000000-1.237256 qam19
13291000000-1.237256 qam20
14299000000-0.937256 qam21
15307000000-0.737256 qam22
16315000000-0.937256 qam23
17323000000-1.237256 qam24
18339000000-237256 qam26
19347000000-237256 qam27
20355000000-237256 qam28
21363000000-237256 qam29
22371000000-237256 qam30
23379000000-237256 qam31
24387000000-2.237256 qam32
1Locked37.6670
2Locked37.6730
3Locked37.3690
4Locked37.3201474
5Locked35.5668294
6Locked36.61159534
7Locked37.647934
8Locked37.6690
9Locked37.6720
10Locked37.6630
11Locked37.6700
12Locked37.3920
13Locked37.6750
14Locked37.6870
15Locked37.3600
16Locked37.6590
17Locked37.6700
18Locked37.31110
19Locked37.61030
20Locked37.6980
21Locked37.3670
22Locked37.6500
23Locked37.6700
24Locked37.6530
1537000005.1512064 qam10
2394000005.1512064 qam12
3462000005.1512064 qam11
4603000005.1512064 qam9
3ATDMA0000
4ATDMA0000
  • 8
Message 6 of 15
27/10/2020 19:26:54noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/10/2020 14:45:24criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/10/2020 09:09:16Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/10/2020 08:49:53noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/10/2020 06:22:0noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt022+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/10/2020 06:22:0ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/10/2020 17:27:46criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/10/2020 19:22:0noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt022+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/10/2020 19:22:0ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/10/2020 16:52:16criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/10/2020 09:48:24Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/10/2020 18:00:4noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt022+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/10/2020 18:00:4ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/10/2020 17:01:16noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt022+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/10/2020 17:01:16ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/10/2020 16:36:59Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/10/2020 16:36:35Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/10/2020 16:36:30criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/10/2020 16:36:30Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 24.99K
  • 1.44K
  • 3.18K
Message 7 of 15
Downstream levels are a touch on the low side and the upstream is definitely too high.
You'll likely need an engineer.
  • 8
Message 8 of 15
How do I request  an  engineer on here?
The phone centers are a nightmare at the moment!
The engineer came last monday, so im surprised he didn't see anything then!
where is the root of the problem for something like this?
If i reset the router with the pin again, is that going to make a difference or is it in the cabinet that's the issue?
  • 24.99K
  • 1.44K
  • 3.18K
Message 9 of 15
You can check all the cables are seated correctly and are nice and tight.
Giving the router a reboot won’t do any harm and you can repost the stats again after that and see if they have changed.
  • 8
Message 10 of 15
Like in my original message, I have tried several ethernets, the fibre cable is in tight on both ends.
i have done several reboots, what im asking is if a hard factory reset will help, i dunno the root cause.
Again, how do I ask for an engineer on here?
