on 11-05-2022 09:56
Hello,
I am trying to setup this router with my VM network.
I followed all the guides, switched the Hub4 to modem mode, shutted it down, turned on the DHCP on the router and followed all the other guides in this forum.
Nothing seems to work, and weirdly enough, even if in modem mode, the Hub is still broadcasting the wifi network, but of course no other device can log in.
What am I doing wrong?
https://www.amazon.co.uk/TP-Link-Next-Gen-Gigabit-Wireless-1201Mbps/dp/B089YXY2YH/?th=1
on 11-05-2022 19:31
To check:
1) Your router is set to router mode and the WAN port is set to DHCP.
2) You hub really is in modem mode. I cannot transmit a WiFi signal if it’s in this mode. The other way to check is to plug in two devices with Ethernet cables, only one should work.
3) Ethernet cable between hub and modem is ok.
on 11-05-2022 20:04
on 11-05-2022 20:05
Apparently is a problem with VM, And I should really wait 24hrs.
Hub4 lights do not change in modem mode, Ans on the deco the wan light is orange
on 11-05-2022 20:09
on 11-05-2022 20:10
Still White 🙂 which doesn't give any clues
on 11-05-2022 22:34
on 09-11-2022 07:55
Did this ever get resolved as I am experiencing the same issues.
I have had it connected and set up but then the 2G doesn’t work and keeps disconnecting.
on 09-11-2022 15:53
yes it was something on the VM side. Call the call centre and ask them about
