on 03-01-2023 16:25
I have just replace a SH3 with a 5. I have 3 UniFy extenders but cannot get them to work - the wifi is still coming from the SH. I've tried changing to Modem only without success. Can anyone give me a simple step by step method to get the extenders to operate?
on 03-01-2023 17:08
I set up modem mode, connect the hub to a laptop, type 192.168.100.1 and all I get is a message saying No Internet.
03-01-2023 17:12 - edited 03-01-2023 17:14
In modem mode your laptop should be set to DHCP. Reboot the Hub with the laptop attached, and it should get a WAN IP and internet access
Also note in modem mode you can only have one ethernet cable attached to the Hub, i.e. to the laptop or to a 3rd party Router.
on 03-01-2023 17:19
DHPC? How do you do that?
on 03-01-2023 17:23
Just set the laptop's NIC to get an automatic IP address, i.e. do not set any values manually.
on 03-01-2023 17:37
on 03-01-2023 18:01
What are "UniFy extenders", do you mean UniFi wireless access points? If so, what model/s, I have a lot of experience of UniFi equipment.
