  • 21
Fantazein
Separating 2.4ghz and 5ghz on super hub 3.0
How do you go about separating the 2.4ghz and 5 ghz on a super hub 3.0 as having issues with my security cameras which only work with 2.4ghz
  • 9.5K
  • 991
  • 1.5K
Re: Separating 2.4ghz and 5ghz on super hub 3.0
Go into the Hub3 settings. Type in http://192.168.0.1 into your web browser’s url box) and login with settings password on the Hub's base sticker (or your own if you changed it). Then in Advanced>wireless>signal disable "channel optimisation" – click apply changes.
Then, go to advanced>wireless>security, rename the 2.4 & 5 GHz network ssid's. Just change 'em to whatever you like and something that will differentiate them (e.g - xxxxx2 & xxxxx5) -- use the same password if you like, Then, apply settings and restart the Hub. Your 2 wifi networks will now be clearly separated - and you can then select the network you want to connect to individually from the "available networks" list on each device. 5 GHz is usually better and subject to less interference (and is better for iDevices ) than the 2.4 one - although this one has the better "range" and some older/cheaper/dumber devices can only use this one.
