on 03-02-2022 21:18
We have installed the hub 5 and our internet speed is so much better, however my sons both have Samsung phones and they are unable to connect to the hub.
it shows on their wifi lists but then just will not connect. Have tried updating their phones, soft resetting phones, restarting router.
Everything else connects great, except these Samsung devices.
Any ideas?
on 10-03-2022 20:26
Hi @sb85uk
Are you able to provide the information that @Kath_F request? Or have you been able to fix the issue at your end?
Please let us know if you have been able to fix this and what you have done so that we can advise anyone else having the same issues.
on 14-06-2022 11:38
My son is having same issue with 5ghz on Samsung s21 Ultra, it disconnects after a few days and you have to reset the hub to allow it to connect again.
on 07-08-2022 14:32
I'm having the same issue with my Samsung S22 ultra. I have to reset the Hub 5 every few days in order for my phone to connect, anyone have a solution yet?
on 09-08-2022 07:35
Is there any update from the Tech team pls?
on 11-08-2022 08:43
Hey amoVM, thanks for posting and for the query. Could you please let us know what sort of update you've been expecting from us so I can chase this up for you? Is this regarding the WiFi connection issue with the Samsung device you purchased? Cheers
on 11-08-2022 09:08
I was told that your Hub5 tech team were going to review this issue experienced with some Samsung products.
on 08-10-2022 09:01
Did you get any resolution on this problem? I’ve just installed a hub 5 and whilst my wife’s older Samsung phone connects to the 5Ghz Wi-Fi my newer A53 will only successfully connect to the 2.4Ghz at usually sub 100Mbps. It also randomly says no internet and resorts to mobile data. We have a relatively small house and I’m probably no more than a 5 metres away from the hub.
Thankfully everything (as far as I can tell) seems to be working.
on 08-10-2022 09:26
No didnt get a fix from VM.
on 08-10-2022 11:19
on 10-10-2022 16:02
Sorry to hear this is still unresolved for you.
I will check back with the team to see if there are any further updates or any further information we might need to help resolve this sooner.
Mt apologies again for any inconvenience this issue has caused.
