on 06-04-2022 11:37
Having loads of problems with 1gb connection and SamKnows won’t see my hub, so unable to check my actual speed etc. Any thoughts?
on 11-04-2022 13:57
Hi shaneclare,
I am so sorry you are having issues with SamKnows, do you have a screenshot of your error (without personal information)
Zoie
on 11-04-2022 14:19
on 12-04-2022 15:57
As it turns out after being told by Virginmedia's telephone support for the last two and a half months that everything was fine and the problem was all mine a new router has solved all my issues, not being able to use the Sanknows software, slow speeds (as low as 7mb on a 1gig connection on wired) and constant drop outs and buffering on my music streamers. Not very happy at all, the poorest customer service in over thirty years as a client. I may be going elsewhere.
on 12-04-2022 17:16
Doesn't work for me either. I'm running in router mode as I always have, and it used to work fine.
Screenshot in https://community.virginmedia.com/t5/Networking-and-WiFi/5GHz-wifi-disables-itself-hardware-issue/td...
on 13-04-2022 08:30
Might be worth insisting on a new hub, mine turned out to be the problem.
on 13-04-2022 10:47
@shaneclare wrote:Might be worth insisting on a new hub, mine turned out to be the problem.
Nothing wrong with the hub
on 13-04-2022 11:37
Sorry, When I said router I meant to say Hub, a new Hub 4 solved all my problems.
on 13-04-2022 13:52
Curiously, the RealSpeed test is working fine again today.
on 14-04-2022 02:01
Mine has not worked for a while now but it is inconsistent, so I do not really bother with it but was curious what changed.
Not on WIFI, (Router Mode+Wired) and I am not using a VPN, again nothing changed.
