on 01-02-2022 19:34
Previously had an SNR issue in December which was fixed.
Seems to be back again after an issue in my area yesterday. (Hemel Hempstead, HP2)
Fault checker isn't showing issues currently, however it did yesterday.
Posting stats just because it's the normal thing to do,
Hub3, modem mode, the usual. - all wired.
I should note: the T3 error count on channel 4 is historical from the previous SNR issue.
Looks like this needs to be fixed, again.
QAM is all over the place, not amused.
1 | 539000000 | -0.7 | 38 | 256 qam | 17 |
2 | 411000000 | 1.7 | 40 | 256 qam | 1 |
3 | 419000000 | 1.5 | 40 | 256 qam | 2 |
4 | 427000000 | 1.2 | 40 | 256 qam | 3 |
5 | 435000000 | 0.7 | 40 | 256 qam | 4 |
6 | 443000000 | 0.5 | 40 | 256 qam | 5 |
7 | 451000000 | 0.5 | 40 | 256 qam | 6 |
8 | 459000000 | 0.5 | 40 | 256 qam | 7 |
9 | 467000000 | 0.5 | 40 | 256 qam | 8 |
10 | 475000000 | 0.4 | 40 | 256 qam | 9 |
11 | 483000000 | 0.2 | 38 | 256 qam | 10 |
12 | 491000000 | 0 | 38 | 256 qam | 11 |
13 | 499000000 | -0.2 | 40 | 256 qam | 12 |
14 | 507000000 | -0.2 | 40 | 256 qam | 13 |
15 | 515000000 | -0.2 | 40 | 256 qam | 14 |
16 | 523000000 | -0.5 | 40 | 256 qam | 15 |
17 | 531000000 | -0.5 | 40 | 256 qam | 16 |
18 | 547000000 | -1.2 | 38 | 256 qam | 18 |
19 | 555000000 | -1.2 | 40 | 256 qam | 19 |
20 | 563000000 | -1.2 | 38 | 256 qam | 20 |
21 | 571000000 | -1.5 | 38 | 256 qam | 21 |
22 | 579000000 | -1.7 | 38 | 256 qam | 22 |
23 | 587000000 | -1.7 | 38 | 256 qam | 23 |
24 | 595000000 | -1.5 | 38 | 256 qam | 24 |
1 | Locked | 38.9 | 921 | 0 |
2 | Locked | 40.3 | 374 | 0 |
3 | Locked | 40.3 | 384 | 0 |
4 | Locked | 40.3 | 299 | 0 |
5 | Locked | 40.3 | 176 | 0 |
6 | Locked | 40.3 | 246 | 0 |
7 | Locked | 40.9 | 505 | 0 |
8 | Locked | 40.3 | 391 | 0 |
9 | Locked | 40.3 | 271 | 0 |
10 | Locked | 40.3 | 423 | 0 |
11 | Locked | 38.9 | 257 | 0 |
12 | Locked | 38.9 | 410 | 0 |
13 | Locked | 38.9 | 717 | 0 |
14 | Locked | 40.9 | 267 | 0 |
15 | Locked | 40.3 | 381 | 0 |
16 | Locked | 40.3 | 350 | 0 |
17 | Locked | 40.3 | 450 | 0 |
18 | Locked | 38.9 | 517 | 0 |
19 | Locked | 40.3 | 536 | 0 |
20 | Locked | 38.9 | 1443 | 0 |
21 | Locked | 38.6 | 761 | 0 |
22 | Locked | 38.9 | 718 | 0 |
23 | Locked | 38.6 | 779 | 0 |
24 | Locked | 38.9 | 959 | 0 |
1 | 46200263 | 44.5 | 5120 | 32 qam | 1 |
2 | 32600000 | 44 | 5120 | 16 qam | 3 |
3 | 39400039 | 44.3 | 5120 | 64 qam | 2 |
4 | 25800126 | 43.3 | 5120 | 32 qam | 4 |
1 | ATDMA | 0 | 0 | 4 | 0 |
2 | ATDMA | 0 | 0 | 3 | 0 |
3 | ATDMA | 0 | 0 | 4 | 0 |
4 | ATDMA | 0 | 0 | 9830 | 0 |
on 01-02-2022 19:36
30/01/2022 19:03:19 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
27/01/2022 23:39:52 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
27/01/2022 07:03:18 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
23/01/2022 19:47:1 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
23/01/2022 19:03:17 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/01/2022 01:53:18 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
20/01/2022 07:03:16 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
18/01/2022 10:30:54 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
13/01/2022 06:03:16 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
10/01/2022 03:02:59 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
06/01/2022 05:33:16 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
05/01/2022 05:07:25 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
02/01/2022 17:33:15 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
31/12/2021 09:04:36 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
30/12/2021 05:33:14 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
26/12/2021 20:54:45 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
26/12/2021 17:33:13 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
25/12/2021 20:12:10 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
23/12/2021 05:33:13 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
20/12/2021 08:37:30 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
Would be fantastic if we can have this truly ironed out,
SNR issues aren't the most fun thing to deal with, sadly.
More than happy to reply/PM with any additional info.
on 01-02-2022 19:37
Check with Area faults on 0800 561 0061 If you have a VM landline 150 this goes down to post code level. You could also try the web page http://www.virginmedia.com/servicechecker
If no faults found:
Call Customer Services on 0345 454 1111/150 if you have a VM landline or wait a day or two for a VM staff member to get to your post.
01-02-2022 19:53 - edited 01-02-2022 20:18
Sadly isn't showing up on Area faults when calling in, nor on the online checker currently.
Guess I'll have to wait and see!
hopefully the connection holds up! fingers crossed! 🙂
Going to put my stats after a fresh hub restart:
1 | 46200000 | 44.5 | 5120 | 32 qam | 1 |
2 | 32600000 | 43.8 | 5120 | 16 qam | 3 |
3 | 39400000 | 44.3 | 5120 | 64 qam | 2 |
4 | 25800000 | 43.3 | 5120 | 32 qam | 4 |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
05-03-2022 01:02 - edited 05-03-2022 01:23
Bump, since I seem to have been skipped over.
Packet loss appearing on my graph as of 11 ~ 11:30PM ish on 4th March.
Snapshot:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/fad71f69f760b30487772557a55fce5e88...
Live:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/3f9a0c6eff35d57ae0f42e221bb1b8b92039be2d
I'll post my stats up, again.
Large amounts of PRE-RS on certain channels.
1 | 539000000 | -0.7 | 40 | 256 qam | 17 |
4 | 427000000 | 1.4 | 40 | 256 qam | 3 |
5 | 435000000 | 0.9 | 40 | 256 qam | 4 |
6 | 443000000 | 0.7 | 40 | 256 qam | 5 |
7 | 451000000 | 0.7 | 40 | 256 qam | 6 |
8 | 459000000 | 0.7 | 40 | 256 qam | 7 |
10 | 475000000 | 0.5 | 40 | 256 qam | 9 |
11 | 483000000 | 0.2 | 40 | 256 qam | 10 |
12 | 491000000 | 0.2 | 38 | 256 qam | 11 |
13 | 499000000 | 0 | 40 | 256 qam | 12 |
15 | 515000000 | 0 | 40 | 256 qam | 14 |
16 | 523000000 | -0.2 | 40 | 256 qam | 15 |
17 | 531000000 | -0.4 | 40 | 256 qam | 16 |
18 | 547000000 | -1 | 38 | 256 qam | 18 |
19 | 555000000 | -1 | 40 | 256 qam | 19 |
20 | 563000000 | -1 | 38 | 256 qam | 20 |
21 | 571000000 | -1.4 | 38 | 256 qam | 21 |
22 | 579000000 | -1.5 | 38 | 256 qam | 22 |
23 | 587000000 | -1.5 | 38 | 256 qam | 23 |
24 | 595000000 | -1.4 | 38 | 256 qam | 24 |
1 | Locked | 40.3 | 841 | 0 |
2 | Locked | 40.3 | 254 | 0 |
3 | Locked | 40.3 | 242 | 0 |
4 | Locked | 40.3 | 217 | 0 |
5 | Locked | 40.9 | 132 | 0 |
6 | Locked | 40.3 | 157 | 0 |
7 | Locked | 40.9 | 433 | 0 |
8 | Locked | 40.3 | 232 | 0 |
9 | Locked | 40.3 | 186 | 0 |
10 | Locked | 40.3 | 340 | 0 |
11 | Locked | 39.3 | 266 | 0 |
12 | Locked | 38.9 | 292 | 0 |
13 | Locked | 40.3 | 808 | 0 |
14 | Locked | 40.3 | 247 | 0 |
15 | Locked | 40.3 | 325 | 0 |
16 | Locked | 40.3 | 320 | 0 |
17 | Locked | 40.3 | 477 | 0 |
18 | Locked | 38.6 | 541 | 0 |
19 | Locked | 40.3 | 546 | 0 |
20 | Locked | 38.6 | 1087 | 0 |
21 | Locked | 38.9 | 2066 | 0 |
22 | Locked | 38.9 | 2429 | 0 |
23 | Locked | 38.6 | 81895 | 0 |
24 | Locked | 38.9 | 487775 | 0 |
1 | 46200000 | 45 | 5120 | 64 qam | 1 |
2 | 32600000 | 44 | 5120 | 64 qam | 3 |
3 | 39400000 | 44.5 | 5120 | 64 qam | 2 |
4 | 25800000 | 43.8 | 5120 | 32 qam | 4 |
1 | ATDMA | 0 | 0 | 5 | 0 |
2 | ATDMA | 0 | 0 | 1 | 0 |
3 | ATDMA | 0 | 0 | 5 | 0 |
4 | ATDMA | 0 | 0 | 4 | 0 |
05-03-2022 01:04 - edited 05-03-2022 01:07
Network access | Allowed |
Maximum Number of CPEs | 1 |
Baseline Privacy | Enabled |
DOCSIS Mode | Docsis30 |
Config file | cmreg-vmdg505-bbt057-b.cm |
SFID | 276018 |
Max Traffic Rate | 117000047 |
Max Traffic Burst | 42600 |
Min Traffic Rate | 0 |
SFID | 276017 |
Max Traffic Rate | 10500047 |
Max Traffic Burst | 16320 |
Max Concatenated Burst | 16320 |
Scheduling Type | BestEffort |
28/02/2022 07:49:46 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
25/02/2022 16:18:23 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/02/2022 19:49:45 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
23/02/2022 08:36:34 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/02/2022 07:49:44 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
20/02/2022 20:17:45 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
17/02/2022 19:49:43 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
17/02/2022 01:59:34 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
14/02/2022 07:49:42 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
13/02/2022 17:32:30 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
10/02/2022 19:49:41 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
07/02/2022 14:23:11 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/02/2022 07:36:13 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
02/02/2022 07:09:27 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
As you can see, Huge PRE-RS errors on Channel 23 + 24 with packet loss on the TBB graph,
the PRE-RS only climbed when the packet loss started.
Also noticed channels on 2 + 4 on the upstream still dropping back to 32QAM.
on 06-03-2022 20:10
Made a previous post, been accidentally skipped for the past month or so.
Can this be flagged for the mods/staff.
https://community.virginmedia.com/t5/Networking-and-WiFi/SNR-issue-again/m-p/4958043#M464484
Unfortunately the connection is now looking the most terrible it has been for a while.
Snapshot from yesterday:
Live:
Stats from yesterday can be seen in the thread I linked at the top of this post.
However all upstream channels are now jumping around, often staying at 16QAM for long amounts of time.
Please help me out if you can!
on 07-03-2022 09:26
Hi Icantcrabhere,
Thank you for your post. We're sorry to hear you're still having issues with your broadband service.
I have taken a look on our system and I have seen some errors that would require an engineer to resolve.
I have booked a visit in for you. Please check your online account for the details regarding the visit.
^Martin
09-03-2022 14:23 - edited 09-03-2022 14:39
Hi there,
Technician has been and agreed about potential noise being let in on the network, but not from my home.
Apparently he had talked to colleagues about it, prior to the visit. - but I need this verified.
So as of yet we obviously have no resolution.
He showed me something on his phone,
Wondering if you could inform me further about the following reference number: F009688492
This is what he showed me, however I'd like to make sure it it 100% correct.
Has a "Date opened" of March 8th, 12:33,
Estimated end date: 15th march 12:35.
Priority: P4
Get back in touch when you can, thanks!
on 11-03-2022 15:37
Good Afternoon @Icantcrabhere,
I've been able to look into your local area, and it appears that the outage is showing as an end time of 18:00 today
Please update us beyond this time frame to let us know how the services are performing
Kindest regards,
David_Bn
