  • 5
Nathjones28
Message 1 of 10
SMARTHUB CONNECTION HELP
Hello,
I’m new to Virgin, I had my install four days ago, however I’m finding my broadband speed varies drastically. Sometimes my connect will be 200mbps, other times it drops as low as 15mbps.
My WiFi connection also drops out on various occasions, and my router has done 3 restarts on its own since Monday.
Anyone have any advice?
  • 19.32K
  • 1.68K
  • 4.23K
Message 2 of 10
Re: SMARTHUB CONNECTION HELP
Would need to check the signal levels if could go to http://192.168.0.1 or if using modem mode http://192.168.100.1 clicking router status top right or bottom of page depending on hub [no need to login - depending on hub] and if could copy/paste the downstream, upstream, network log, don't worry about the formatting we can easily read it.. try and avoid using screen shots..
when your doing the speed tests is this via wired/wireless?, if wireless can you test via wired
Click to learn more about VIP
Use Kudos to say thanks
  • 5
Nathjones28
Message 3 of 10
Why is there errors from May? When I only had the kit for the last week?
30/05/2019 09:31:50ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/05/2019 09:31:53Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/05/2019 09:33:26ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/05/2019 09:33:29ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/05/2019 09:33:45Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/05/2019 14:20:43Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/05/2019 14:20:53Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/05/2019 03:18:31Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/05/2019 03:18:36Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/06/2019 01:01:16criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/06/2019 01:01:16Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/06/2019 01:01:20Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:45criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/06/2019 07:22:48noticeUnit has been restored to factory defaults from a software issued command;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/01/1970 00:02:14criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/07/2019 17:28:47ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/07/2019 17:56:26ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/07/2019 17:56:26noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsxl20016u+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/07/2019 21:02:26criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
1461999324.375512064 qam1
2258000004.375512064 qam4
3325999594.375512064 qam3
4394000534.375512064 qam2
3ATDMA0000
4ATDMA0000
1450750000-140256 qam31
21947500001.740256 qam8
32027500001.740256 qam9
42107500001.740256 qam10
52187500001.740256 qam11
62267500001.440256 qam12
72347500001.240256 qam13
8242750000140256 qam14
92507500001.240256 qam15
102587500001.240256 qam16
112667500001.240256 qam17
12274750000140256 qam18
132827500001.240256 qam19
14290750000140256 qam20
15298750000140256 qam21
163067500000.940256 qam22
173147500000.740256 qam23
183227500000.740256 qam24
19402750000-0.740256 qam25
20410750000-0.540256 qam26
21418750000-140256 qam27
22426750000-1.240256 qam28
23434750000-140256 qam29
24442750000-0.940256 qam30
1Locked40.300
2Locked40.950
3Locked40.950
4Locked40.350
5Locked40.960
6Locked40.370
7Locked40.350
8Locked40.950
9Locked40.990
10Locked40.360
11Locked40.960
12Locked40.360
13Locked40.350
14Locked40.960
15Locked40.360
16Locked40.350
17Locked40.370
18Locked40.350
19Locked40.9160
20Locked40.3180
21Locked40.350
22Locked40.330
23Locked40.960
24Locked40.360
  • 19.32K
  • 1.68K
  • 4.23K
Message 4 of 10
Those stats all showing fine, since hub 3 are requested back by virginmedia possible might be a reconditioned hub
  • 5
Nathjones28
Message 5 of 10
Or a faulty hub.....
  • 19.32K
  • 1.68K
  • 4.23K
Message 6 of 10
Possible
  • 5
Nathjones28
Message 7 of 10
So what’s the solution?
  • 1.66K
  • 92
  • 168
Message 8 of 10
Hi there Nathjones28,
Thanks for posting - sorry that you're having some issues with your broadband at the moment.
Are you having the speed issues via a wired connection as well as a WiFi connection?
Have you tried any self diagnostics via our free Connect App? We also have our in-app help team that you can message if you are still having issues after going through the checks.
Let us know how things are after a reboot and over a wired connection.
Cheers
Katie - Forum Team
  • 5
Nathjones28
Message 9 of 10
The issue is wireless. It continually drops from devices.
the WiFi tool shows me that I have good connection in all rooms.
  • 12.63K
  • 482
  • 1.13K
Message 10 of 10
Router mode is buggy use the hub in modem mode and get your own wireless router with 1Gb ports.
