  • 15
Muller
SHub 3 modem power/stat levels?
Have had numerous wifi/connection problems etc. Put shub 3 into modem mode and using tp link router. Rang tech helpline and they have arranged for an engineer to call out. These are the stats from the superhub 3 menu. Are they normal range? Thanks. upstreammodem.png
  • 2.47K
  • 231
  • 620
Re: SHub 3 modem power/stat levels?
Only one upstream channel and the power level is way too high. Downstream is way too low.
Dave
"The late great Douglas Adams: A common mistake that people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools."
  • 15
Muller
Is there anything I should say to the engineer? ie make him change the cable wiring, replace superhub 3 etc. I don't want him/her to fob me off. Thanks.
  • 2.47K
  • 231
  • 620
Just show them the power levels and check they're in spec' before they leave. If they're any good they'll decide on the best course of action.
Downstream power levels should be between -6 and +10, upstream less than 51 (ideally in the 40's).
Dave
  • 15
Muller
Thanks for the info. With regards to only one upstream channel, is that just because of the superhub 3 being in modem mode? Or a network fault/superhub fault? Thanks.
  • 2.47K
  • 231
  • 620
They always have 2, 3 or 4 upstream channels as far as I'm aware, regardless of mode.
If I was a betting man I'd go for network fault, I've known to be wrong though.
Dave
