  • 18
cpugenesis
Message 1 of 9
SH3 Internet Connection Drops Packet Loss
Hi Guys,
Hope someone is able to help with our connection,
Having issue with it being unstable and briefly disconnecting every day.  Noticed it shortly after the SH2AC to SH3 swap.
* Upgraded from SH2AC a few months ago (which had been fine for years)
* Had tech out several weeks ago who confirmed we had full signal, and saw no issues, but swapped the SH3 for a new SH3 (like for like).
Issues seem to persist in both router mode and modem mode (connected to a separate router).
NETGEAR > VM HUB 3  modem mode
https://www.thinkbroadband.com/broadband/monitoring/quality/share/83febfabef00cb80f3088e557f982e9854...
  • 18
cpugenesis
Message 2 of 9
Re: SH3 Internet Connection Drops Packet Loss
20/10/2018 11:15 stats
General Configuration
Network access Allowed
Maximum Number of CPEs 1
Baseline Privacy Enabled
DOCSIS Mode Docsis30
Config file V0dea97109ea7aa00.cm
SFID 140209
Max Traffic Rate 230000000
Max Traffic Burst 42600
Min Traffic Rate 0
Primary Upstream Service Flow
SFID 140208
Max Traffic Rate 12700000
Max Traffic Burst 16320
Min Traffic Rate 0
Max Concatenated Burst 16320
Scheduling Type BestEffort
2018-10-20 10:12:39.00 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=48::d3*****:13;CMTS-MAC=00:01:*****:5b;CM-QOS=1.1;CM-VER=3.0;
2018-10-20 10:12:39.00 Warning! RCS Partial Service;CM-MAC=48::d3*****:13;CMTS-MAC=00:01:*****:5b;CM-QOS=1.1;CM-VER=3.0;
2018-10-20 10:12:40.00 Warning! RCS Partial Service;CM-MAC=48::d3*****:13;CMTS-MAC=00:01:*****:5b;CM-QOS=1.1;CM-VER=3.0;
2018-10-20 10:12:41.00 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=48::d3*****:13;CMTS-MAC=00:01:*****:5b;CM-QOS=1.1;CM-VER=3.0;
2018-10-20 10:12:42.00 Warning! RCS Partial Service;CM-MAC=48::d3*****:13;CMTS-MAC=00:01:*****:5b;CM-QOS=1.1;CM-VER=3.0;
2018-10-20 10:12:42.00 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=48::d3*****:13;CMTS-MAC=00:01:*****:5b;CM-QOS=1.1;CM-VER=3.0;
2018-10-20 10:12:46.00 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=48::d3*****:13;CMTS-MAC=00:01:*****:5b;CM-QOS=1.1;CM-VER=3.0;
2018-10-20 10:12:46.00 Warning! RCS Partial Service;CM-MAC=48::d3*****:13;CMTS-MAC=00:01:*****:5b;CM-QOS=1.1;CM-VER=3.0;
2018-10-20 10:12:48.00 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=48::d3*****:13;CMTS-MAC=00:01:*****:5b;CM-QOS=1.1;CM-VER=3.0;
2018-10-20 10:12:48.00 Warning! RCS Partial Service;CM-MAC=48::d3*****:13;CMTS-MAC=00:01:*****:5b;CM-QOS=1.1;CM-VER=3.0;
2018-10-20 10:12:49.00 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=48::d3*****:13;CMTS-MAC=00:01:*****:5b;CM-QOS=1.1;CM-VER=3.0;
2018-10-20 10:12:50.00 Warning! RCS Partial Service;CM-MAC=48::d3*****:13;CMTS-MAC=00:01:*****:5b;CM-QOS=1.1;CM-VER=3.0;
2018-10-20 10:12:51.00 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=48::d3*****:13;CMTS-MAC=00:01:*****:5b;CM-QOS=1.1;CM-VER=3.0;
2018-10-20 10:12:51.00 Warning! RCS Partial Service;CM-MAC=48::d3*****:13;CMTS-MAC=00:01:*****:5b;CM-QOS=1.1;CM-VER=3.0;
2018-10-20 10:12:52.00 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=48::d3*****:13;CMTS-MAC=00:01:*****:5b;CM-QOS=1.1;CM-VER=3.0;
2018-10-20 10:12:52.00 Warning! RCS Partial Service;CM-MAC=48::d3*****:13;CMTS-MAC=00:01:*****:5b;CM-QOS=1.1;CM-VER=3.0;
2018-10-20 10:12:57.00 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=48::d3*****:13;CMTS-MAC=00:01:*****:5b;CM-QOS=1.1;CM-VER=3.0;
2018-10-20 10:12:57.00 Warning! RCS Partial Service;CM-MAC=48::d3*****:13;CMTS-MAC=00:01:*****:5b;CM-QOS=1.1;CM-VER=3.0;
  • 11.7K
  • 347
  • 678
Forum Team (Retired) Samantha_L
Message 3 of 9
Hi cpugenesis,
Thanks for posting on the community.
My apologies you are having an issue with the broadband connection.
Looking at your account, the line and hub have come back as fine with no errors. The network segment is running stable and there have been no time-outs reported.
With your BQM graph, which I assume is live, is looking much better from today. Has anything changed at all?
Sam
  • 18
cpugenesis
Message 4 of 9
Thanks, it is a bit of a weird one - That's right the link is to a live graph, although I do have snapshots of daily graphs.
Looking at the daily graph now we seem to have had 1 drop off at mid day and 1 just after 6pm,  Modem shows 17:20 SYNC Timing Synchronization failure.
  • 18
cpugenesis
Message 5 of 9
More examples and logs
2018-10-24 21:00:47.00 SYNC Timing Synchronization failure - Loss of Sync
2018-10-24 21:08:10.00 SYNC Timing Synchronization failure - Loss of Sync
2018-10-24 21:13:59.00 SYNC Timing Synchronization failure - Loss of Sync
2018-10-24 21:14:10.00 SYNC Timing Synchronization failure - Loss of Sync
2018-10-24 23:56:56.00 No Ranging Response received - T3 time-out
2018-10-25 01:44:32.00 RCS Partial Service;
2018-10-25 02:37:59.00 SYNC Timing Synchronization failure - Loss of Sync
2018-10-25 02:38:00.00 RCS Partial Service
2018-10-25 02:45:54.00 SYNC Timing Synchronization failure - Loss of Sync;
2018-10-25 02:45:54.00 RCS Partial Service
2018-10-25 02:52:33.00 SYNC Timing Synchronization failure - Loss of Sync;
2018-10-25 02:52:33.00 RCS Partial Service;
2018-10-25 03:22:35.00 SYNC Timing Synchronization failure
2018-10-25 03:22:36.00 RCS Partial Service;
2018-10-25 08:06:17.00 SYNC Timing Synchronization failure - Loss of Sync
2018-10-25 08:06:17.00 RCS Partial Service;
  • 10.87K
  • 406
  • 1.24K
Forum Team (Retired) Nicola_C
Message 6 of 9
Hello cpugenesis
Sorry you are still having some loss of sync issues, there was a little bit of intermittent noise in the area however it is difficult to be certain this is the cause. The hub wasn't provisioned correctly on our ladp so I have remedied that, apologies as it caused a reboot. May we see how it goes for the next few days please, kindly keep us updated.
Thank you
Nicola
Virgin Media Forum Team
  • 18
cpugenesis
Message 7 of 9
Thanks for the help.  I've also been round the house and made sure all connections are nice and tight to avoid any ingress.   I imagine that the extra channels and higher frequencies of DOCSIS 3 are that bit more sensitive to noise.
Agree - lets see how it goes over the next couple of days.
  • 18
cpugenesis
Message 8 of 9
Hi guys,
Starting to look a bit better,  Will continue to monitor over the next few days.
Friday seemed to stay the same with dropouts throughout the day.
Saturday starting to look up,  graph shows 1 dropout at 4am but otherwise okay,
Sunday we had 2 periods of dropout during the day but otherwise okay.
Monday as of 8pm,  so far so good - no issues.
bradley987
Message 9 of 9
Hi, I'm on the same local area network as the original poster cpugenesis.
While the internet was fine for almost a week, the exact same issues have resurfaced over the last 3-4 days.
Last 24 hours 14:00 07/11/2018 - 08/11/2018:
Note: I briefly rebooted the modem once at exactly 13:00.
Network logs show the same swarm of "SYNC Timing Synchronization failure - Loss of Sync" and "RCS Partial Service" errors.
In a one hour period from 13:00 to 14:00 our Downstream channels accumulated – on average – 17,000 Post RS Errors per channel per hour. The highest being 26266 Post RS Errors per hour on channel 23
Any real time services such as: online games/voice communications are impossible to use with them disconnecting every few minutes, logging back in then getting disconnected again.
More casual internet usage is also frustrating, effectively rolling a dice whether a page will load.
Logs:
Modem Network Logs 08/11/2018
2018-11-08 13:12:38.00 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=48:d3:xx:xx:xx:xx;CMTS-MAC=00:01:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
2018-11-08 13:12:38.00 Warning! RCS Partial Service;CM-MAC=48:d3:xx:xx:xx:xx;CMTS-MAC=00:01:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
2018-11-08 13:12:39.00 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=48:d3:xx:xx:xx:xx;CMTS-MAC=00:01:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
2018-11-08 13:12:40.00 Warning! RCS Partial Service;CM-MAC=48:d3:xx:xx:xx:xx;CMTS-MAC=00:01:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
2018-11-08 13:12:40.00 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=48:d3:xx:xx:xx:xx;CMTS-MAC=00:01:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
2018-11-08 13:12:41.00 Warning! RCS Partial Service;CM-MAC=48:d3:xx:xx:xx:xx;CMTS-MAC=00:01:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
2018-11-08 13:12:42.00 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=48:d3:xx:xx:xx:xx;CMTS-MAC=00:01:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
2018-11-08 13:12:42.00 Warning! RCS Partial Service;CM-MAC=48:d3:xx:xx:xx:xx;CMTS-MAC=00:01:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
2018-11-08 13:12:46.00 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=48:d3:xx:xx:xx:xx;CMTS-MAC=00:01:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
2018-11-08 13:12:48.00 Warning! RCS Partial Service;CM-MAC=48:d3:xx:xx:xx:xx;CMTS-MAC=00:01:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
2018-11-08 13:13:20.00 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=48:d3:xx:xx:xx:xx;CMTS-MAC=00:01:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
2018-11-08 13:13:20.00 Warning! RCS Partial Service;CM-MAC=48:d3:xx:xx:xx:xx;CMTS-MAC=00:01:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
2018-11-08 13:13:51.00 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=48:d3:xx:xx:xx:xx;CMTS-MAC=00:01:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
2018-11-08 13:13:51.00 Warning! RCS Partial Service;CM-MAC=48:d3:xx:xx:xx:xx;CMTS-MAC=00:01:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
2018-11-08 13:13:57.00 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=48:d3:xx:xx:xx:xx;CMTS-MAC=00:01:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
2018-11-08 13:13:58.00 Warning! RCS Partial Service;CM-MAC=48:d3:xx:xx:xx:xx;CMTS-MAC=00:01:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
Modem Network Logs 05/11/2018
2018-11-05 17:14:27.00 Warning! RCS Partial Service;CM-MAC=48:d3:xx:xx:xx:xx;CMTS-MAC=00:01:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
2018-11-05 17:14:27.00 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=48:d3:xx:xx:xx:xx;CMTS-MAC=00:01:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
2018-11-05 17:14:53.00 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=48:d3:xx:xx:xx:xx;CMTS-MAC=00:01:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
2018-11-05 17:14:54.00 Warning! RCS Partial Service;CM-MAC=48:d3:xx:xx:xx:xx;CMTS-MAC=00:01:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
2018-11-05 17:14:55.00 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=48:d3:xx:xx:xx:xx;CMTS-MAC=00:01:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
2018-11-05 17:14:55.00 Warning! RCS Partial Service;CM-MAC=48:d3:xx:xx:xx:xx;CMTS-MAC=00:01:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
2018-11-05 17:14:57.00 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=48:d3:xx:xx:xx:xx;CMTS-MAC=00:01:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
2018-11-05 17:14:57.00 Warning! RCS Partial Service;CM-MAC=48:d3:xx:xx:xx:xx;CMTS-MAC=00:01:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
2018-11-05 17:14:59.00 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=48:d3:xx:xx:xx:xx;CMTS-MAC=00:01:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
2018-11-05 17:14:59.00 Warning! RCS Partial Service;CM-MAC=48:d3:xx:xx:xx:xx;CMTS-MAC=00:01:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
2018-11-05 17:15:01.00 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=48:d3:xx:xx:xx:xx;CMTS-MAC=00:01:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
2018-11-05 17:15:01.00 Warning! RCS Partial Service;CM-MAC=48:d3:xx:xx:xx:xx;CMTS-MAC=00:01:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
2018-11-05 17:15:02.00 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=48:d3:xx:xx:xx:xx;CMTS-MAC=00:01:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
2018-11-05 17:15:02.00 Warning! RCS Partial Service;CM-MAC=48:d3:xx:xx:xx:xx;CMTS-MAC=00:01:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
2018-11-05 17:15:03.00 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=48:d3:xx:xx:xx:xx;CMTS-MAC=00:01:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
2018-11-05 17:15:03.00 Warning! RCS Partial Service;CM-MAC=48:d3:xx:xx:xx:xx;CMTS-MAC=00:01:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
2018-11-05 17:15:04.00 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=48:d3:xx:xx:xx:xx;CMTS-MAC=00:01:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
2018-11-05 17:15:04.00 Warning! RCS Partial Service;CM-MAC=48:d3:xx:xx:xx:xx;CMTS-MAC=00:01:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
2018-11-05 17:15:10.00 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=48:d3:xx:xx:xx:xx;CMTS-MAC=00:01:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
