ronniefesta
  • 12
Message 1 of 11
Rubbish Speed!!! How many upload channels should I have
Hey, I have 24 download channels and only 1 upload.
I read something about you supposed to have 4? I got in touch with VM and they fobbed me off saying everything was as it should be
ive just upgraded to 500mb and im getting around 210/17 on a wired connection.Shocking
267000000
Locked
Ranged Upstream Channel (Hz)
46199975
Locked
Provisioning State
Online
1267000000040256 qam17
22750000000.940256 qam18
32830000002.540256 qam19
42910000003.240256 qam20
52990000002.540256 qam21
6307000000340256 qam22
73150000004.440256 qam23
83230000003.940256 qam24
9331000000440256 qam25
10371000000440256 qam26
113790000004.640256 qam27
123870000004.640256 qam28
133950000004.540256 qam29
144030000003.940256 qam30
154110000004.440256 qam31
164190000004.640256 qam32
17427000000440256 qam33
184350000002.740256 qam34
194430000002.240256 qam35
204510000002.740256 qam36
21459000000340256 qam37
224670000002.740256 qam38
234750000002.940256 qam39
244830000003.940256 qam40
1Locked40.3810
2Locked40.3210
3Locked40.980
4Locked40.3290
5Locked40.3480
6Locked40.9460
7Locked40.3300
8Locked40.3570
9Locked40.31570
10Locked40.3730
11Locked40.3610
12Locked40.9680
13Locked40.31330
14Locked40.31370
15Locked40.31270
16Locked40.91180
17Locked40.31090
18Locked40.91790
19Locked40.31810
20Locked40.31440
21Locked40.91510
22Locked40.31900
23Locked40.32020
24Locked40.31790
Upstream bonded channelsChannel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID
14619997557512064 qam5
Upstream bonded channelsChannel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt053-b.cm
SFID311594
Max Traffic Rate575000000
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID311593
Max Traffic Rate38520000
Min Traffic Rate0
Max Concatenated Burst16320
Scheduling TypeBestEffort
Tags (1)
ronniefesta
  • 12
Message 2 of 11
Re: Rubbish Speed!!! How many upload channels should I have
22/06/2021 07:54:39criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/06/2021 22:10:14ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/06/2021 23:07:16criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/06/2021 10:10:13ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/06/2021 00:38:32criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/06/2021 22:10:12ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/06/2021 02:44:50criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/06/2021 10:10:12ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/06/2021 21:44:25criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/06/2021 22:55:10ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/05/2021 17:44:36criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/05/2021 10:55:10ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/05/2021 17:06:58criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/05/2021 22:55:10ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/05/2021 16:28:54criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/05/2021 22:30:3ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/05/2021 20:16:27criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/05/2021 10:20:31ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/05/2021 07:58:30criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/05/2021 22:20:31ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 24.02K
  • 2.54K
  • 4.36K
Message 3 of 11
Dreadful
Should be 4 Up channels the one you have is at max power and struggling. Try this and see if they return.
Do a Hub “pinhole reset” - make sure the 2 passwords on the Hub sticker are still there and legible first ! Disconnect any ethernet cables from the Hub (leave the coax connected), and then with the Hub still "switched on" throughout, press pin in firmly with paper clip/SIM tray tool or similar "thin thing" and hold it firmly for at least 60 seconds, release the pin, leave for 5’ to stabilise - dont manually switch it off at any time. See if that sorts it. Note the passwords for all your devices connecting on wifi will revert to that on the sticker - you will have to login to the Hub to change it back to what you have
  • 24.02K
  • 2.54K
  • 4.36K
Message 4 of 11
Should have added...
_________________
If you haven’t already, set up a free and secure “Broadband Quality Monitor” to continually monitor the state of your connection and record any true network dropouts , latency issues, packet drops, Overutilisation issues, etc - it will thus allow you to differentiate between those and simple wifi dropouts. It does it 24/7/365 and it keeps a visual record of any/all of your network disconnections, useful data to have to match to the Network logs (in your Hub settings) and also in discussions with VM - note it will take a few hours to start seeing a sensible picture - post up the “link” to the “share live graph” (as per instructions on the TB website) when it starts to develop.
ronniefesta
  • 12
Message 5 of 11
Hi John,
Firstly, ive reset my hum using the pinhole method you described, and it had factory reset everything.
I was using my hub in modem only mode and a netgear nighthawk router. this used to be great but of late, its shocking.
My hub went into router mode so i thought id have a play with it under different scenarios.
my iphone xr started receiving speeds of 450+/18, yet my laptop plugged via ethernet was about 200/18.
a few more tests and basicially I have removed the netgear router all together and left my hub in router mode.
I have a mancave at the bottom of the garden connected via ethernet, and the pc is now getting 500+/17, so much faster... Still the upload issue though and I still have only 1 upstream bonded channel.
Looks like I will have to call.
Thanks for your help
14620000057512064 qam5
ronniefesta
  • 12
Message 6 of 11
think broadband graph...
this is from when the hub was in model only mode - since ive gone back to router mode the ip has changed thats being monitored
https://www.thinkbroadband.com/broadband/monitoring/quality/share/eff7e58cd737bd26c6fa2a83c7cff348ed...
hope thats the link you need
  • 8.48K
  • 675
  • 1.52K
Message 7 of 11
You need a technician’s visit to correct, that one upstream channel is way too high power level. Call customer services or wait a few days for a VM staff member to get to your post.
One thing you can do in the meantime is to check if you have an attenuator in the circuit, it’s a small component marked with a dB value like 6dB. If you have a normal attenuator not a forward path attenuator it will reduce the downstream signal level, but cause an increase in the upstream power level. A forward path attenuator will only affect the downstream power level.
ronniefesta
  • 12
Message 8 of 11
Tudor,
Called VM and they coming out tomorrow apparently, so will see what they say.
Thanks for the advice.
curiosity, should I have a forward path attenuator then? not had chance to check yet
ronniefesta
  • 12
Message 9 of 11
VM came out this am. Replaced the "SuperHub", reduced a splitter outside from 5 down to 2 seeing as I am using less tv boxes now, and all is now working well, I have 4 upload channels too.
Thanks all for your help
  • 8.48K
  • 675
  • 1.52K
Message 10 of 11
Glad you got it fixed.
