JCD16
Router will not return to normal from flashing green
Our Hub 3.0 went off last night at around 3am, and after resetting 4 times since then we still do not have wifi. Everytime we reset the Base LED remains on normal (white) for a short time before all the LEDs flash red once, then green once, until the base LED flashes green and the wifi LED stays visibly green. Any help would be much appreciated thanks
  • 21
Nicknacks2611
Re: Router will not return to normal from flashing green
It could be to do with new software update, that’s being pushed, Which can take upto 20mins to download & install.
Switch off & unplug
Leave for a minute.
Reconnect & switch, have a cuppa & hopefully it would of redownloaded or resynced itself.
The update will restart the Hub once or twice.
Hope this helps.
Nick
JCD16
Thanks for any responses
We have got it back up and running now we believe it was downloading the new software update.
Thanks again
  • 11.49K
  • 501
  • 748
Forum Team (Retired) Josh_RW
Hi JCD16,
Welcome to the Community!
I'm sorry to hear you've had trouble with your connection but glad to hear it's working again. Keep an eye on it and pop back to the Community if you get any more issues.
All the best
Josh
