ollieHooper
Message 1 of 8
Router / wifi issues
Our router seems to keep resetting itself randomly throughout the day. Bottom white light flashes then the middle 3 green lights come on and slowly go out.
There are times the laptops either won't connect to the wifi or they have full wifi signal but no connection.
I ran the diagnosis test from the hub homepage and got this. I was sitting right next to the hub with the laptop.
sasperella
Message 2 of 8
Re: Router / wifi issues
We're having same issue, I thought there were problems in July when we were away and I couldn't always connect to security cameras at home.
Since start of August I've been keeping a record of when the router has dropped connection when I've been at home. It's been nearly everyday throughout August and that's based on me only been in early morning/evenings! It's as if the router is rebooting itself as it's usually only down for a couple of minutes.
Today it's just gone off again but this time it's rebooted twice within 5 minutes.
I'm going to try and get through to virgin media as it seems since they announced their raising prices again, broadband has started playing up!!!!
  • 5.89K
  • 453
  • 986
Hero
Message 3 of 8
Please raise separate post, if extremely difficult to reply when the symptoms may look the same, but the root cause could be entirely different.
Please go into your hub on 192.168.0.1 and post your up/downstream stats and network log (on separate posts).
There are 10 types of people: those who understand binary and those who don't and F people out of 10 who do not understand hexadecimal
ollieHooper
Message 4 of 8
20/08/2019 09:55:17criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/08/2019 09:55:17criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/08/2019 09:55:18criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/08/2019 09:55:18criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/08/2019 09:55:19criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/08/2019 09:55:19criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/08/2019 09:55:20criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/08/2019 09:55:20criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/08/2019 09:55:21criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/08/2019 09:55:21criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/08/2019 09:55:22criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/08/2019 09:55:22criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/08/2019 09:55:23criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/08/2019 09:55:23criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/08/2019 09:55:24criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/08/2019 09:55:24criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/08/2019 09:55:25criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/08/2019 09:55:25criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/08/2019 09:55:32noticeReceived REG-RSP while in REG-HOLD1 state;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/08/2019 11:45:32critical
ollieHooper
Message 5 of 8
Downstream
1243000000538256 qam14
21390000005.338256 qam1
31470000005.438256 qam2
4155000000538256 qam3
5163000000538256 qam4
61710000005.138256 qam5
71790000005.338256 qam6
81870000005.338256 qam7
91950000005.338256 qam8
102030000005.338256 qam9
11211000000538256 qam10
12219000000538256 qam11
132270000005.138256 qam12
14235000000538256 qam13
152510000004.538256 qam15
162590000004.438256 qam16
172670000004.338256 qam17
182750000004.338256 qam18
192830000004.338256 qam19
202910000004.338256 qam20
212990000004.438256 qam21
223070000004.540256 qam22
233150000004.538256 qam23
243230000004.538256 qam24
1Locked38.650
2Locked38.680
3Locked38.970
4Locked38.670
5Locked38.9190
6Locked38.9190
7Locked38.6200
8Locked38.6200
9Locked38.9180
10Locked38.660
11Locked38.650
12Locked38.660
13Locked38.980
14Locked38.640
15Locked38.640
16Locked38.950
17Locked38.950
18Locked38.960
19Locked38.950
20Locked38.670
21Locked38.970
22Locked40.970
23Locked38.6100
24Locked38.915
0
ollieHooper
Message 6 of 8
UP
1394000004.15512064 qam4
2462000004.2512064 qam3
3537000004.225512064 qam2
4603000004.25512064 qam1
3ATDMA0000
4ATDMA0000
sasperella
Message 7 of 8
Spoiler
Thanks I was going to raise a separate post but when I started typing the new subject I just get a list of similar issues.
Anyway been in touch with virgin media today and seems there's been an ongoing issue in our area for some time and been worked on, despite the status on the app stating all ok
P.s. as an AP I understand both thanks!
  • 5.89K
  • 453
  • 986
Hero
Message 8 of 8
Stats are fine. Possibly noise ingress in your area. Phone customer services and report the problem.
