on 13-07-2022 10:22
My Router has a red light I am on M350mb speed I can only get 105mb with a direct LAN (cat5e) cable. I have tried several resets inc a pin hole reset, the router always come back with a red light.
The wireless signal is a lot worse at only 60mb. The router is on a shelf and is well ventilated and is not overheating.
Is the router faulty and in need of replacement.
Steve
on 13-07-2022 16:14
HI Stevenzbd,
Thank you for your post.
This isn't good to hear and I am sorry for the experience you've had. If you've done the above and there has been no change I will send you over a private message to arrange getting this resolved for you.
Cheers,
Ryan.
on 25-07-2022 09:30
Thanks the router was replaced and now all is good and working great.
Steve
on 27-07-2022 09:44
Morning Stevenzbd
That's great to know its all working as expected now.
Sorry for any inconvenience this may have caused you.
Gareth_L
