Router continually rebooting - Virgin unwilling to help!
olliewaite
Just browsing
I've been having issues with my Virgin broadband for months and have now reached a point where Virgin are unwilling to help.
The Wi-Fi router will continually reboot multiple times every day, so I have to hotspot from my phone for work calls regularly. When I check the status of the broadband I always get told to wait 24 hours before anyone can be called.
A couple of weeks ago they finally agreed to send a technician round who said the 'signals were off' and replaced the router. The issues are still persisting and have not been resolved with the new router. I can now also see both the old and new Wi-Fi network when I search for networks on my laptop.
As in the image below, the top one 'VM9641453' is the new one and the 'VM8789532' is the old one - he took away the old router and password so I am unable to connect to the old one, should it even be there seen as it is now completely redundant without the password?
I have raised a complaint about this and was told that my internet usage had gone up massively in the last month - there is no reason for this, perhaps something to do with now having two networks? They also said that the issues were probably caused by my internet speed with my current package (125mbps) being insufficient for 1-2 people working from home and tried to get me to upgrade to a higher speed for more money! They also said they could see I'd been disconnected over 50 times in the last month be refused to acknowledge there was an error.
I asked for a technician to come round and they said I would have to pay £25 as there is no fault. Please can anyone advise what to do as Virgin seem unwilling to help.
I've included below the error log from the router and can provide more detail if needed.
8 REPLIES 8
Cardiffman282
Superfast
Ignore offshore customer services. They know nothing and are only interested in sales commission due to their miserable basic pay.
Please post all of your downstream and upstream hub stats here.
Thanks!
12580000050.5512064 qam14
23260000050.5512064 qam13
33940000050.5512064 qam12
44620000050.5512064 qam11
1ATDMA0020
2ATDMA0010
3ATDMA0000
4ATDMA0000
1362750000440256 qam29
22267500002.438256 qam12
3234750000340256 qam13
4242750000238256 qam14
5250750000340256 qam15
62587500002.938256 qam16
72667500004.340256 qam17
82747500003.540256 qam18
9282750000440256 qam19
102907500003.740256 qam20
11298750000440256 qam21
123067500003.740256 qam22
13314750000440256 qam23
143227500003.740256 qam24
15330750000440256 qam25
163387500003.940256 qam26
17346750000440256 qam27
18354750000440256 qam28
193707500003.940256 qam30
203787500003.540256 qam31
21386750000340256 qam32
223947500002.540256 qam33
234027500002.740256 qam34
244107500002.940256 qam35
1Locked40.950
2Locked38.900
3Locked40.960
4Locked38.900
5Locked40.300
6Locked38.900
7Locked40.900
8Locked40.900
9Locked40.360
10Locked40.960
11Locked40.900
12Locked40.360
13Locked40.340
14Locked40.900
15Locked40.350
16Locked40.300
17Locked40.360
18Locked40.330
19Locked40.900
20Locked40.3130
21Locked40.960
22Locked40.900
23Locked40.940
24Locked40.950
I can't see the pictures at time of replying. The stats are broadly okay but the upstream power levels look a little high to me.
I remain confused as to how your old network can still apparently broadcast its SSID. Have you got other network kit like powerline adapters or boosters that have perhaps not been updated to the new SSID?
The images seem to have been removed not sure why but I've copied and pasted the network log below.
They have now allowed me to book another technician for next Wednesday without paying the £25 so we will see if that helps!
02/06/2023 12:08:24noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/06/2023 12:08:24ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/06/2023 11:38:24noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/06/2023 11:38:24ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/06/2023 11:08:24noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/06/2023 11:08:24ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/06/2023 11:06:44criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/06/2023 10:25:15noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/06/2023 10:25:15ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/06/2023 09:43:59noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/06/2023 09:43:59ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/06/2023 09:15:10Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/06/2023 00:53:25criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/06/2023 00:53:7Warning!ToD request sent - No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/06/2023 00:52:25criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/06/2023 00:52:22Warning!B-INIT-RNG Failure - Retries exceeded;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/06/2023 00:51:25criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/06/2023 00:42:33criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/06/2023 00:41:27criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/06/2023 00:40:47Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
They are like a metronome at times pulsing every 30 minutes.
Set up a BQM and monitor its pattern.
Superstar
The old SSID looks like a WiFi connection left over from the previous VM Hub.
Deleting the connection for the old SSID should clear that concern.
Superstar
Reading 'the issues' are persisting, does that mean that the both the old and new Hub 3s reboot often ?
If it does, was the PSU replaced during the last engineer's visit ?
Hey ollirwaite, thank you for reaching out and a warm welcome to the community I am so sorry to see you are having some connection issues.
I can see you've spoke to the team since this post, did they manage to get this resolved for you? Thanks
Matt - Forum Team
New around here?
